question: combining components
Ingber · 1310
Offline Ingber
on: November 25, 2024, 10:18:36 PM
Hi,
Before I build my Crack, I have a naive question about kit assembly in general:
A component's specs are only guaranteed within a certain range, often +/- 10% or worse.
I assume that this could potentially cause some audible channel imbalances?
If you are able to measure each component's (resistor, capacitor, tubes etc.) specs with enough precision (say 1%), would it make sense to carefully
combine components (e.g. a resistor below specs in series with another resistor above specs) to reduce channel imbalance?
If so, how would this work for the Crack kit?
Regards,
Ingber Roymans
Reply #1 on: November 26, 2024, 04:55:43 AM
While you can calculate the maximum possible deviation from something like resistor tolerances, these are 1% parts and tubes themselves aren't 1% devices, so you might tighten your channel balance by a few hundredths of a dB, or possibly you could make it slightly worse.  Likewise with something like the electrolytic coupling capacitors in the Crack, you are going to be chasing tiny fractions of a dB that only appear at low frequencies, and these differences will be lower in magnitude than the differences in output between the left and the right headphone drivers themselves.
Reply #2 on: November 26, 2024, 05:31:43 AM
Tube parameters are the most variable, typically +/-30%, ad they drift as the tube ages. So circuits are designed to work well over a range of component values.
Occasionally you can find a data sheet that goes into detail about variability and aging, typically for high-reliability or military spec tubes. An example I just checked is the Tung-Sol data sheet for a 6080WA. It shows a spec for gain (mu) of 1.5 to 2.5.
http://frank.yueksel.org/sheets/127/6/6080WA.pdf
