S.E.X. upgrade C4S problem [resolved]
sprout · 3298
Offline sprout
on: December 01, 2024, 12:58:22 PM
My S.E.X. amp sounded great on headphones before the upgrade installation, but only after a right channel failure that was resolved with a better solder joint at a loose spot. However, after the upgrade, I get 90 v at OB, but get only 1 v at OA. Again a right channel issue, so I don't know if this is an original problem back again, or if it's an upgrade problem. Advice please! Thanks, Jim
« Last Edit: December 11, 2024, 10:02:27 AM by Paul Birkeland »
Online Paul Birkeland
Reply #1 on: December 01, 2024, 06:06:25 PM
I would post build photos.  1V at the output of a C4S would have me looking for metal bits touching each other that shouldn't be (don't forget that the chassis plate counts).
Offline sprout
Reply #2 on: December 02, 2024, 10:26:24 AM
Again, after some solder joint work, I got a correct reading, hooked it up, and it sounded great. Then after half hour of Doobie Brothers, the right channel dropped out. Now I'm getting 1 v at OA again.
So, both before and after the upgrade, I had the right channel drop out. I plan to keep re-soldering each joint on the right channel.
I'll try photos, but it didn't work last effort. It looks like a monkey made it.
Thanks and very sorry to be a pest. Jim
Reply #3 on: December 02, 2024, 10:28:20 AM
R1 on the A side isn't well soldered, could I see photos of the bottom and top of the PC board?
Offline sprout
Reply #4 on: December 03, 2024, 07:31:49 AM
Thanks, I'll re-solder that one. Here are photos of the board, and it is so small, maybe there's contact somewhere.
Reply #5 on: December 03, 2024, 07:33:45 AM
There are definitely some soldering issues here.
The center leg of the MJE5731A on the left side of the photo you posted is probably the worst of the joints on there.
Offline sprout
Reply #6 on: December 11, 2024, 07:39:00 AM
I added some solder and now it works again and sounds great. Thanks for all the help. Here's how I painted the top.
