bottlehead crack with speedball too loud, barely have to turn volume knob
hunkichunki · 2566
Offline hunkichunki
Hey all, loving my crack but one thing..
I find it too loud? I barely have to turn the volume knob to get it to listening levels, let alone to the 12 oclock position which will likely melt my brain. Is there a way to fix that or is that an expected thing?
My running gear is Windows PC - > Ifi pro idsd dac -> bottle head
If I am reading the manual correctly there is a variable output option on your DAC. And presumably there could be a level control in the app you are using with your PC.  Trim either one of those down.
Alternatively, see the Crack FAQ, #3
https://forum.bottlehead.com/index.php?topic=4295.0
Offline hunkichunki
Thanks for this tip. I set it to variable and now I can adjust the crack volume at will :) thanks so much boss!
« Last Edit: December 14, 2024, 05:15:36 AM by hunkichunki »
