Bottlehead Kits
BeePre
Using Crack with BeePre2 - how to wire tape output?
bladerunner80
2417
bladerunner80
Jr. Member
December 27, 2024, 12:27:37 PM
Hi, I have a Crack that I'm hoping to use with my BeePre2. I searched through the forum and came across a tip to wire in tape output. Could someone give a little more info on how to do this (parts needed, what areas to tap into to do this)?
Paul Birkeland
Global Moderator
Hero Member
Re: Using Crack with BeePre2 - how to wire tape output?
Reply #1 on:
December 27, 2024, 01:25:48 PM
The output of the selector switch (A, B, C, and D) are the tape outputs. Red is right +, white is left +, and the adjacent black wires are the grounds for each channel.
bladerunner80
Jr. Member
Reply #2 on:
December 27, 2024, 04:12:48 PM
Thanks for the info Paul. I'm assuming I would attach a pair of RCA jacks using the output method you mentioned above. How have people typically done this in the past, do they attach a RCA cable directly or attach jacks and mount them somewhere on the base or top plate?
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
December 27, 2024, 06:10:13 PM
You could put jacks in the holes we provide for the balanced input transformers, I think that would be the easiest way. Using shielded twisted pair wiring is a good idea, with the shield terminating to the chassis in the BeePre (similar to how the input wiring is done).
bladerunner80
Jr. Member
Reply #4 on:
February 03, 2025, 11:39:19 AM
Thanks Paul, late reply - just started putting the kit together. How does this look?
Paul Birkeland
Global Moderator
Hero Member
Reply #5 on:
February 03, 2025, 11:47:39 AM
That looks great!
Bottlehead Kits
BeePre
