Bottlehead Kits
Sublime Subwoofer Amplifier kit
blown board
blown board
100r05
3541
100r05
Jr. Member
blown board
January 01, 2025, 08:56:26 AM
When I first powered on my sublime amp the pc board sparked a small fire. The black chip I circled on the attached picture is what popped.
Also I double checked everything, What could have gone wrong? What did I miss?
Thank you all for the help
Doc B.
Administrator
Hero Member
Re: blown board
Reply #1 on:
January 02, 2025, 05:24:29 AM
If I'm not mistaken Eileen has already sent a replacement board to you. There's not a whole lot of connections on that kit so aside from a wiring error I would be double checking the voltage trim of the power supply and make sure those green connectors on the PC board are making good contact with the wires installed in them. Also be sure no bare wires are making contact wth the chassis.
100r05
Jr. Member
Re: blown board
Reply #2 on:
January 05, 2025, 10:17:46 AM
all fixed! however I am quite disappointed with the sublime/subette/pipette/moreplay/SEX set up I have. Just not great in my little office.
Thanks for all the help
Paul Birkeland
Global Moderator
Hero Member
Re: blown board
Reply #3 on:
January 05, 2025, 10:26:05 AM
Did you set your SEX amp for 4 ohm operation?
100r05
Jr. Member
Re: blown board
Reply #4 on:
January 05, 2025, 10:48:48 AM
I think I did when I built it. how do I double check?
Paul Birkeland
Global Moderator
Hero Member
Re: blown board
Reply #5 on:
January 05, 2025, 12:21:52 PM
You'd need to go into the manual and review the output transformer wiring instructions and compare those to what you have on your amp to see how it's currently wired.
Doc B.
Administrator
Hero Member
Re: blown board
Reply #6 on:
January 05, 2025, 05:32:31 PM
I'd like to help if possible. Can you give any more info as to what is causing your disappointment?
Bottlehead Kits
blown board
