Question regarding Moreplay upgrade kit.
Thermioniclife · 2555
Offline Thermioniclife
on: January 15, 2025, 10:03:05 AM
Does the upgrade kit take the 9.4 Vac and output 6.3Vdc and removing the dropping resistors for the heaters?
Thanks in advance.
Online Paul Birkeland
Reply #1 on: January 15, 2025, 10:27:22 AM
Yes.
Reply #2 on: January 15, 2025, 11:37:20 AM
Roger that PB. i have a motorized Alps 10 k log pot from a failed / abandoned project that I can use to give remote volume control on the Moreplay..
being that I'm handicapped that would be cool. I use the Moreplay in my kitchen with a s3x and a pair of Overnight sensations, sounds good. IIRC Alps specs state 4.5 to 6.5 Vdc to operate the motor and I believe I measured the current draw of the motor was 50ma max. Can use a 7805 voltage reg to power a 2 channel IR relay board. Thanks for the reply.
Regards, Lee
Reply #3 on: January 15, 2025, 03:22:36 PM
If the current draw for the motor is that low, you can use the DC output from one of the heater regulators on the upgrade board.
