100K vs 250K volume control
Colonl_Charisma · 1544
Offline Colonl_Charisma
on: January 25, 2025, 10:02:57 AM
I acquired a Goldpoint stepped attenuator (47 steps), and I’m going to install the resistors myself.
If I installed the resistors to have 250K ohm resistance, would that allow me to have more range in volume before it gets too loud?
For instance, I currently have a 100K PEC pot with the 75K and 33 K pre-attenuation resistors installed in my amp. I only use about 1/3 of my potentiometer’s turn before it becomes too loud.
Ross
Fiio K11 R2R --> Bottlehead Crack --> HD600
Offline hmbscott
Reply #1 on: January 25, 2025, 10:26:44 AM
Assuming you use the resistor values suggested by GoldPoint for your attenuator, the dB step size will be the same whether it's a 100K or a 250K pot. The reason it will be the same is that a pot attenuates using a voltage divider circuit, and its the ratio of the resistances that sets the attenuation in dB, not the absolute value of the resistances.
You could select a custom set of resistance values that would change the pot taper if you wanted, making the attenuation steps bigger than Goldpoint's suggested values. Bigger steps means the pot attenuation range would be bigger, that is more attenuation to start with, and so you would have to turn the volume pot higher to reach the point that's now too loud. This will work regardless of whether it's a 100K or a 250K pot. You will have bigger volume changes per step though.
Increasing the pot total resistance would change the input impedance and that could make your system more sensitive to noise, so I recommend against that.
Scott
Reply #2 on: January 25, 2025, 10:29:33 AM
No, that's not how attenuator impedance works.
You could change the 75K resistors to 100K and the 33K resistors to 5K.
Reply #3 on: January 25, 2025, 10:58:13 AM
Thank you both! Very informative answers, and I’ll increase the pre-attenuation resistors.
Ross
