Bottlehead Kits
Legacy Kit Products
Paramount
Soft Start Driver Board .1uf 630V capacitor
Paully
4448
Paully
Sr. Member
February 23, 2011, 11:35:11 AM
If my memory serves there was a .1uf 630V cap on the old board that it was worth upgrading. I replaced it with a .2uf 600V teflon. There is a polypropylene cap on the new board same value, can I, should I, reuse the teflon on the new board? Thanks!
Paul
Global Moderator
Hero Member
Re: Soft Start Driver Board .1uf 630V capacitor
Reply #1 on:
February 23, 2011, 01:34:55 PM
The value is chosen, along with the associated resistor (Cc and Rc), to stabilize the internal feedback network. They are not precision parts, but I don't recommend using different values. You can try it, it might work out well ...
Paully
Sr. Member
Reply #2 on:
February 23, 2011, 02:04:40 PM
Eh, I will use the proper value. Upgrading the cap worth the trouble?
edit: I went and looked in the amps, I actually did use a .1uf 600V. So no reason not to use that again. Thanks!
Last Edit: February 23, 2011, 02:11:10 PM by Paully
debk
Sr. Member
Reply #3 on:
July 02, 2012, 01:42:42 PM
I have the same question. I have seen pictures of this capacitor upgraded with "boutique" capacitors. Is this a worth while upgrade?
Debra
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite 300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Doc B.
Administrator
Hero Member
Reply #4 on:
July 02, 2012, 01:46:36 PM
It gets into the realm of subtle changes but yeah, it does seem to make a small difference.
Bottlehead Kits
Legacy Kit Products
Paramount
