Wiring for goldpoint pot
Mgaith656 · 1148
Offline Mgaith656
on: February 15, 2025, 07:52:36 PM
Hello,
Can someone please explain how the ground wiring is done for the goldpoint pot or any other pcb where it has just two ground holes (one on each level) and the total ground wires for the crack are three. Do i need to connect the two ground wires coming from the 9pin socket together and then pass them through the top level ground hole of the board and solder(top level being when mounted to the crack)? what about the jumper wire in this case?
Thanks for your help.
Reply #1 on: February 16, 2025, 05:26:42 AM
It is 100% equivalent to the stock potentiometer.  You need to maintain the jumper.   Just put everything onto the Goldpoint in exactly the same way it's put on the stock potentiometer.
