I have a similar setup, the difference is in the preamp. My set up has gone through an evolution like you are considering.
Version 1: Eros 2 > Moreplay > Schiit Lokius (used primarily to convert single-ended to balanced) > ACA Mono blocks running with the balanced inputs (sounds great!)
Version 2: Eros 2 > Moreplay > Schiit Lokius (used primarily to convert single-ended to balanced) > Hypex Nilai Stereo 500DIY (sounds better than ACA's, very surprising!)
Version 3: Eros 2 > Moreplay > Stereomour II (built w/o the preamp features, has all the kit upgrades, NOS 2A3 RCA Black Plates) Sounds end-game good.
I think it's fair to say that while each amp was an improvement, none of them significantly changed the character of the system sound, the improvement expressed itself primarily in increased engagement and reduced listening fatigue. Someone with better ears and more experience might be able to identify the sonic changes that are responsible for that, but that's how it hits me.
All of my Bottlehead components are significantly upgraded regarding caps resistors and tubes.
« Last Edit: February 26, 2025, 08:05:53 PM by hmbscott »
Scott
[U-Turn Theory > Hana ML > Eros IIw/Sowter 1490 SUT] & [iMac M1 Apple Music lossless/hi res > HQPlayer > Denafrips Ares II] >> Moreplay >> Stereomour II >> Hsu ULS-15 Sub & DIY DML Speakers
