Voltage at terminals 25 and 30 BeePre [resolved]
Yossihaimberg · 3924
Offline Yossihaimberg
on: February 27, 2025, 10:15:34 AM
Hi,
Checking the voltage at 25 and 30 shows 0 VDC....  (should be close to 10 VDFC per page 55 of the manual)
All other readings so far were on target:
31 and 33 = 250VDC
Filament out 6.3 VDC on both sides
4 and A4 or A1   445 ohm
14 and B1 or B4  445 ohm
I checked and triple-checked the wiring; they all seem fine.
Please help....
« Last Edit: February 28, 2025, 02:36:00 PM by Paul Birkeland »
Reply #1 on: February 27, 2025, 02:55:49 PM
Do you have 300Bs in the tube sockets?
If so, carefully measure the DC voltage between pins 1 and 4 on each 4 pin socket and report that back.
Reply #2 on: February 28, 2025, 07:47:41 AM
A(1-4) 4.95 VDC
B(1-4) 4.98 VDC
Reply #3 on: February 28, 2025, 10:39:49 AM
What DC voltages do you see at pin 2 on each 4 pin socket?
Reply #4 on: February 28, 2025, 10:49:38 AM
Between pin 2 and which pin?
Reply #5 on: February 28, 2025, 10:52:15 AM
Ground.
Reply #6 on: February 28, 2025, 11:08:06 AM
A(2-ground)  103 VDC
B(2-ground)  103.4 VDC
Reply #7 on: February 28, 2025, 01:43:30 PM
Problem solved!!
 I may have forgotten to insert the 30-0Bs before checking the voltage. The readings now are correct at 10VDC between 14 and 25 or 30.
Thanks again for your amazing support!
