Paramour rebuild with MQ 60H choke - what size CAP?
CentripetalMan · 20289
Offline CentripetalMan
on: March 09, 2025, 05:19:47 AM
I am going to rebuild my Paramours and finally use the 60H MQ chokes with brass endbells. Using 2A3 tubes, what size should the parafeed capacitor be?  Thanks!
Reply #1 on: March 09, 2025, 05:57:12 AM
Which output transformers are you going to use with these?
Reply #2 on: March 10, 2025, 07:08:24 AM
I'm going to use 4K parafeed transformers.
Reply #3 on: March 10, 2025, 07:22:53 AM
PJ always has more insightful thoughts about stuff like this than I do, especially since it's his design.  I'd imagine he'd specify a smaller cap if you planned to use the Speco output transformer, or something a bit heftier if you planned to use our current OT-2 or the Edcor-sourced upgrades for the older Paramours.   Something around 7uF should be fine with the 60H/OT-2.  I'd cut that value down a bit if you're planning to stick with the Speco.
Reply #4 on: March 10, 2025, 08:32:14 AM
PB nailed it.
Reply #5 on: March 10, 2025, 10:33:50 AM
Hi Paul,
Thanks for the reply. The transformers are 4K parafeed made by ElectraPrint.
Reply #6 on: March 10, 2025, 02:30:24 PM
Can you take some pictures of one next to a ruler?
Reply #7 on: March 14, 2025, 05:40:35 AM
Hi Paul,  I've attached the photos of the transformer.
Reply #8 on: March 18, 2025, 03:09:10 PM
That is the same lamination size as the OT-2 we use in the SEX and Stereomour (bigger than what's in the tiny Speco), but not quite as large of a stack (fewer of those laminations in the stack).  I think 7uF should be just fine.
