Mainline Questions
Tabaia · 24713
Offline Tabaia
on: March 24, 2025, 06:35:35 PM
Hello , I am just staring on the Bias / Regulator board, first stumble is the 499 ohm resistor - which way up/down?
Yellow on the top or red on the top?
Reply #1 on: March 24, 2025, 07:01:30 PM
Resistors are not directional.
Offline Tabaia
Reply #2 on: March 24, 2025, 07:18:39 PM
great , thank you.
Offline Tabaia
Reply #3 on: March 24, 2025, 07:19:31 PM
hence no info added about the direction in the manual :)
Offline Tabaia
Reply #4 on: March 24, 2025, 08:26:07 PM
Could i please get confirmation that this capacitor is in the correct position.
Offline Tabaia
Reply #5 on: March 24, 2025, 09:17:44 PM
I think i figured it out - Could someone confirm the position of the film Capacitor
Reply #6 on: March 25, 2025, 04:44:06 AM
The second way is more correct than the first, but both would work.
Offline Tabaia
Reply #7 on: March 25, 2025, 04:05:18 PM
Hi Paul,
Thank you for your feedback.
Would it be ok to send you pictures of the boards with components and soldering for some feedback?
Reply #8 on: March 25, 2025, 04:13:26 PM
You can post them here.  So far, I'd suggest either turning the iron temp up all the way or holding on the joints a little longer so they flow out a bit more.
Offline Tabaia
Reply #9 on: March 25, 2025, 04:38:53 PM
Hi Paul,
Here are the pictures.
Thanks for your support
Reply #10 on: March 25, 2025, 05:54:20 PM
Definitely more heat is needed, and a tiny bit of extra solder.
Offline Tabaia
Reply #11 on: March 25, 2025, 06:01:40 PM
so, my understanding is that I should go over all the solder joints, reheat and add a little solder as well.
Reply #12 on: March 25, 2025, 06:22:44 PM
Yes, when you get the solder hot enough, it will suck into the board a bit.
Offline Tabaia
Reply #13 on: April 03, 2025, 07:48:12 PM
Hi,
I am going to get a copper chassis made and hopefully a brass plate for the dials and switches.
Would you have a DXF available ?
Offline Tabaia
Reply #14 on: April 04, 2025, 04:17:56 PM
I have done some re-soldering according to what I think is correct from the instructions given.
Would you kindly have a look and let me know it this is better?
