Mainline Questions
Tabaia · 24718
Offline Tabaia
Reply #30 on: May 14, 2025, 04:29:30 PM
275V test.
Reads 366V
What to do?
Reply #31 on: May 15, 2025, 04:53:39 AM
What AC line voltage did you measure and how did you wire your power transformer primary?
Offline Tabaia
Reply #32 on: May 15, 2025, 05:59:00 PM
What AC line voltage initially measured between 230 and 247
I used the wiring for Greater than 235V and Less than 245V.
Also Reading the manual and getting my head around this i realise that the reading I have for the board 235V is probably OK.
Manual says it should read between 300-500VDC , mine reads 366VDC.
I assume that is fine?
Reply #33 on: May 16, 2025, 04:41:35 AM
Yes, all is well.   The voltage at that node will be relatively high when there's nothing built in the amp to load it down.
Offline Tabaia
Reply #34 on: May 17, 2025, 09:16:28 PM
Great !Im on track.
Thank you.
Offline Tabaia
Reply #35 on: June 04, 2025, 06:04:34 PM
Hello,
I have finally come to the point of checking the Ohm's
Here are my current issues:
Mostly where it say 0 - my multimeter reads Ohm
And on terminals 19 & 22 i get a reading of 200Ohm's.
What could be the issue?
Looking forward to your response.
Reply #36 on: June 05, 2025, 03:27:31 PM
Could you post some pictures of these readings as they appear on the meter?
Offline Tabaia
Reply #37 on: June 05, 2025, 05:44:16 PM
Here are the readings of terminals 19 and 22
Reply #38 on: June 06, 2025, 04:46:45 AM
That's 200K, which is 200,000 ohms.
Offline Tabaia
Reply #39 on: June 06, 2025, 12:54:19 PM
Ok thanks Paul.
Are those readings ok for those terminals?
The m,anual says otherwise.
Reply #40 on: June 06, 2025, 01:14:04 PM
Ok thanks Paul.
For which terminals?
Offline Tabaia
Reply #41 on: June 06, 2025, 06:52:34 PM
Terminals 19 and 22
Reply #42 on: June 07, 2025, 05:35:21 AM
You have 200K at terminals 19 and 22, which is consistent with what's written in the manual.
Offline Tabaia
Reply #43 on: June 07, 2025, 02:51:57 PM
Hello again,
Just wanted to run my tests by you.
Here is a completed list of all the terminal tests.
It seems that the terminals that have no connection and no grounding all read zero.
Kindly have a look and let me know if there are any issues.
Many thanks
1 - 39.84kΩ
2 - 2.1Ω
3 - 1.2Ω
4 - 1.1Ω
5 - 39.87kΩ
6 - 1.6Ω
7 - 1.3Ω
8 - 1.2Ω
9 - 1.2Ω
10 - 1.2Ω
11 - 1.2Ω
12 - 0.L (zero reading)
13 - 1.3Ω
14 - 0.L (zero reading)
15 - 210.6Ω
16 - 1.3Ω
17 - 0.L (zero reading)
18 - 1.2Ω
19 - 201.5kΩ
20 - 12.20Ω
21 - 1.2Ω
22 - 201kΩ
23 - 1.3Ω
24 - 0.L (zero reading)
25 - 210.2Ω
26 - 1.2Ω
27 - 0.L (zero reading)
28 - 1.3Ω
29 - 0.L (zero reading)
30 - 2Ω
Reply #44 on: June 07, 2025, 04:22:20 PM
Could you double check terminal 20?
