Capacitor spark/pop when volt testing (resolved)
adlehman · 5564
Offline adlehman
on: April 04, 2025, 02:03:10 PM
Hi y'all,
When completing final voltage checks on my Stereomour II, I got to testing terminal 34 and 35, where the 100uf 450v capacitor is connected. When I attached the red lead to terminal 34, it sparked and popped. After that, the terminal gave me no power reading. All of my measurements leading up to that point were correct.
I believe I had shorted the capacitor, but why/how? The fuse is not blown, btw.
Would the logical next step be to replace the capacitor and see what happens?
I have attached pictures of my build for reference. I am still learning about electronics, so thank you for any help and guidance anyone may have. Appreciate ya!
« Last Edit: April 11, 2025, 07:37:06 AM by adlehman »
Offline kgoss
Reply #1 on: April 04, 2025, 03:27:40 PM
Not related to your question but it looks like you are missing one ceramic resistor on one hum pot
Ken Goss
Offline adlehman
Reply #2 on: April 04, 2025, 03:40:12 PM
Whoops, I'm on it!
Thank you!
Reply #3 on: April 04, 2025, 06:51:18 PM
I would imagine the 130 Ohm 2W resistor leading to that terminal blew, likely from the hot end of the cap being briefly shorted to electrical ground.  You can measure each of the 130 ohm resistors while they are still soldered into the amp to check them, just be sure the amp is off.
Offline adlehman
Reply #4 on: April 05, 2025, 04:36:25 AM
I'll check that today and report back, thank you, Paul!
Offline adlehman
Reply #5 on: April 05, 2025, 04:55:32 AM
Paul, I think you are right.
That resistor is giving me no reading now.
Is there anything I should keep in mind as I replace that resistor to make sure I don't have the same outcome?
Again, apologies if I am missing something obvious, still new to this!
Reply #6 on: April 05, 2025, 05:03:00 AM
You probably accidentally touched your probe to multiple terminals.  You can just measure pin 2 on each 4 pin socket instead, and they'll be around 350V or so.
Offline adlehman
Reply #7 on: April 05, 2025, 05:30:11 AM
Got it, thank you! Once everything is swapped out and cleaned up I will report back.
Offline adlehman
Reply #8 on: April 11, 2025, 07:40:39 AM
Paul,
Parts have been swapped out, all fixed up, and now it's singing.
Thank you so much for your help and guidance. Much appreciated!
Offline hmbscott
Reply #9 on: April 11, 2025, 01:35:08 PM
Lovely setup!
Scott
[U-Turn Theory > Hana ML > Eros IIw/Sowter 1490 SUT] & [iMac M1 Apple Music lossless/hi res > HQPlayer > Denafrips Ares II] >> Moreplay >> Stereomour II >> Hsu ULS-15 Sub & DIY DML Speakers
