Crack Assembly Error - Connected 21U to 16U by mistake [resolved]
Ekreks · 3204
Offline Ekreks
My Crack unit passed Resistance checks, was moving on to voltage checks, plugged the unit in saw a little smoke by the 16U cap, powered down immediately. realized my mistake - made the correction.  My question is given I saw a little smoke, I figure I blew the capacitor at 16U. What other damage did I do ? ...and what parts need to be replaced outside of the capacitor?
Thanks for any help.  I feel I was soo close.
Ekreks
« Last Edit: April 24, 2025, 04:19:42 AM by Paul Birkeland »
Offline Ekreks
Reply #1 on: April 21, 2025, 05:38:42 AM
Hello:
I mistakenly connected the 5kw resistor to 16U and 21U by mistake, it should have been 21U and 15 U. I saw smoke from the capacitor, likely blown and needs to be replaced. Any other damage or parts need replacing? I checked the rectifier diodes they ae fine blocking one way, allowing the other.  I do have an lcr meter and checked the caps, they all report 200ish microfarads, I will still replace one I saw the smoke from. I checked the transformer primary and secondary side resistances
I have corrected the wiring. 21U to 15U.
Thanks for any insight/help. Boy do I feel dumb, looked things over and not sure how I missed this. I feel I was so close…
David
Reply #2 on: April 21, 2025, 07:11:28 AM
Can you tell us what kit you are building? That will help us to get your post moved to the proper board and we can better assist you.
Offline Ekreks
Reply #3 on: April 21, 2025, 07:16:34 AM
The bottlehead Crack It. I tested the value of the 270 ohm resistors, the one I mis-wired went bad as well.  I ordered some replacement parts caps and resistor.to replace (correctly).
Offline Ekreks
Reply #4 on: April 21, 2025, 09:22:18 AM
I see topic was moved, thanks.  I'll stand by for any insights.
Reply #5 on: April 22, 2025, 05:58:53 AM
Probably just that resistor needs to be replaced.  The capacitors generally will only fail if you put them in backwards.  Voltage never got to the capacitor mounted to 14/15, so there would be absolutely no reason to replace it.
« Last Edit: April 22, 2025, 06:02:26 AM by Paul Birkeland »
Offline Ekreks
Reply #6 on: April 22, 2025, 07:06:02 AM
Thanks. My LCR meter is reporting the cap is fine. When replacement comes in I'll report back and close this out - hopefully successful..Cheers.
Offline Ekreks
Reply #7 on: April 23, 2025, 02:52:53 PM
Yep. Changed the resistor and all works fine now. Thanks! Unit sounds great.  Dead quiet, needed to drive the signal a little more to the amp, but once I got that balanced, all is well. now on to the speedball.  Cheers!
