Bottlehead Kits
BeePre
Original Bee Pre left channel no output [resolved]
pdxgrampa
4347
pdxgrampa
Full Member
May 27, 2025, 11:29:37 AM
Original Bee Pre with Bee Quiet.
Left Channel no output.C4s A side LEDS lit. B side LEDS not.
Does not follow tube.
Voltages:
11 176 27 0 39 0 D1 NA
12 0 28 0 40 211 D2 0
13 0 29 7.6 41 0 D3 7.6
14 0 30 7.6 42 0 D4 NA
15 184 31 15.2 43 211 D5 NA
16 0.691 32 0 44 00 D6 NA
17 175 D7 177
18 0 D8 NA
D9 177 D9 177
19 0.691
20 0
Greg
Sorry about the messed up columns
Last Edit: June 01, 2025, 06:53:20 AM by Paul Birkeland
Greg
Music Hall 5.1SE,EROS. OPPO 980HD, Music Hall 25.3 Dac. BeePre/BeeQuiet. Paramount V1.1 300B,Orca Deluxe W/ Subs/SPA250s.Stereomour W/Orca Deluxe. Crack W/Speeball(2) .Beyerdynamic 990s.Crackheadphone.
Paul Birkeland
Global Moderator
Hero Member
Re: Original Bee Pre left channel no output
Reply #1 on:
May 27, 2025, 02:42:35 PM
Can you post the IA, OA, IB, OB, and Kreg voltages on each side of the amp?
pdxgrampa
Full Member
Reply #2 on:
May 28, 2025, 10:58:36 AM
Hi Paul,
Here's what i got
A SIDE
IA 182V
0A 146.8V
IB 146.8V
0B 93.6V
KREG 4.3V
B SIDE
IA 183.7V
IB 167.6V
0B 175.1
KREG 1.93V
Thanks for your help Paul
Greg
Greg
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
May 28, 2025, 01:41:29 PM
On the B side, what are your POS IN and POS OUT voltages?
I don't believe your 300B is conducting, but there are many causes for this particular issue.
pdxgrampa
Full Member
Reply #4 on:
May 29, 2025, 07:11:54 AM
I does not look like the cathode is drawing any current (tube is cold and no glow)
POS in is 15.75 volts
POS out is less than a volt decaying to zero
Greg
Greg
Doc B.
Administrator
Hero Member
Reply #5 on:
May 29, 2025, 08:30:28 AM
Check the socket itself. You may have a loose or oxidized contact on pin 1 or 4 (the bigger holes). That could prevent the tube from glowing, which would keep it from conducting.
Paul Birkeland
Global Moderator
Hero Member
Reply #6 on:
May 29, 2025, 08:31:53 AM
No filament current is being drawn, and nothing is being supplied by the filament regulator board. This is most likely a faulty solder joint on that PC board.
Doc B.
Administrator
Hero Member
Reply #7 on:
May 29, 2025, 09:35:25 AM
Oh yup, didn't read the voltages correctly.
pdxgrampa
Full Member
Reply #8 on:
June 01, 2025, 06:48:16 AM
Thanks Paul,
Re flowed the board and all is well.
Good call.
Greg
Greg
Bottlehead Kits
BeePre
