Hi,
I enjoyed Sublime amp with my subettes for a few months. It worked very well, super happy with it.
Now it went silent. No hum, no sound. All LEDs are on. What I have tried so far:
1) Re-do checks according to the manual. The readings seem to all be in order. This should imply that at least the power supply is ok
2) Eyeballed all solder joints and checked the wires
3) Replaced Sublime with a different sub amp, keeping the same input and output wiring. It worked, so it means the problem is not in the rest of my setup.
Is there a way to further test it? Or is there a way to narrow it down to preamp block or the power amp part?
Igor.
« Last Edit: July 09, 2025, 08:19:19 AM by ipetruk »
Crack, Mainline, Pipettes, Subette
