Another failed voltage check
SamJ · 637
Offline SamJ
on: July 10, 2025, 11:22:06 AM
Same as figby, after a good resistance check and lots of comparing picture to result, I have some wayward DC voltages. Of note the two LEDs for the right channel aren't lighting up.  I reflowed all the connections, including at the terminal strips.  All tubes glow normally and I haven't had any pops or buzzing, smoke, etc.  I'm sure I screwed something obvious up.
here are my wayward voltages:
14. 1.856 (170-230)
15. 0.302 (58)
17.  1.007 (0)
19.  2.996 (395)
20.  2.848 (365)
34.  3.014 (392)
36.  .305 (58)
37.  .302 (58)
39.  .302 (58)
40. .299  (58)
Sam
Reply #1 on: July 11, 2025, 05:01:09 AM
Do any of the 130 ohm 2W resistors measure open when you check them with your meter (with the amp off)?  If so, you likely plugged in a 2A3 without paying attention to the fat vs. skinny pins, which will destroy one of those resistors and leave you with dead voltages on one side (or both if you are unlucky and force both 2A3 tubes into the sockets the wrong way).
As always, it's also a good idea to post build photos along with stuff like this.
Offline SamJ
Reply #2 on: July 11, 2025, 05:10:14 AM
PB,
I'll check that and get some photos up as well.  I don't THINK i had the 2A3s installed incorrectly, but there's alway a chance there.
Thanks for the quick response!
Sam
Offline SamJ
Reply #3 on: July 11, 2025, 05:31:50 AM
The 130 ohm 2w resistor between 31 and 34 is reading either open or sometimes something really low like 1.9 (tough to get the leads in there), so looks to be bad.
Reply #4 on: July 12, 2025, 03:03:16 PM
I don't see anything obvious.  I'd snag some replacement 130 ohm 2W resistors from us or online, then attempt to fire up the amp again once that open resistor is replaced.
Offline SamJ
Reply #5 on: July 14, 2025, 04:20:39 AM
On it!  Will report back.
Offline SamJ
Reply #6 on: July 15, 2025, 10:26:17 AM
Swapped out the bad resistor, everything checks as per the instructions EXCEPT 14 is reading 391 (vs. 170-230) and the LEDs for the right channel are still not illuminated.  I reflowed all the connections on the PC board for that channel, and I THINK they all look good (I watched Doc's video on the subject).  The board is looking kinda rough with all the work I did on it, maybe I just start over with a new board?  Or re-re-reflow connections and try again?
Sam
Offline SamJ
Reply #7 on: July 15, 2025, 10:44:41 AM
Forgot pics...
Reply #8 on: July 16, 2025, 12:19:38 PM
Can you see both 12AT7 tubes glowing?  The only joint that often needs reflowing on the C4S board is the center leg of the MJE5731A, and it can be a bad idea to reflow the solder joints for the LEDs.
Offline SamJ
Reply #9 on: Yesterday at 11:01:53 AM
PB,
Replaced the LEDs, and the MJE5731A on the right channel just to be sure.  All 4 LEDs now illuminate, both 12AT7s, but 14 is still reading high (349vs the previous 391).  I checked the MJE5731 joints, they're little silver mounds on both sides.
Reply #10 on: Yesterday at 03:15:27 PM
I can see on your PC board that you haven't heated the joints well enough, as the solder hasn't sunk into the board into the through holes.  Please reheat the MJE5731A joints, especially the center one.  Hold the iron on the joint for a good long 10 seconds to be sure the solder flows into it.
Definitely do not shotgun random parts at something like this, as you can make new problems.
Offline SamJ
Reply #11 on: Today at 01:48:33 AM
Ok, fair enough.  I'll revist the board and report back.
