270K pot on the input of the S.E.X. amp?
keto · 4548
Offline keto
on: March 09, 2011, 01:16:07 AM
Would it be possible/recommendable to use a 270K at the input of the S.E.X. circuit, instead of the stock 100K?
Tom Jones
Reply #1 on: March 09, 2011, 06:21:08 AM
No. The value of the input pot is a compromise - higher resistance provides less load on the source device (good) but it also increases the influence of the Miller capacitance of the power amp's driver grid (bad). In most cases, 50K to 100K is a good compromise.
For the SEX amp, a 270K input pot set at -6dB (worst case) would give a treble rolloff of -1dB at about 13kHz, and -3dB at 26kHz. Many designers prefer to keep the -3dB point at 100kHz whenever possible, on the grounds that more subtle but still audible effects occur before the measured frequency response is compromised. I think this more stringent rule of thumb is situational - sometimes important, sometimes overkill - but it's not a bad guide in general.
Offline coca
Reply #2 on: March 09, 2011, 06:39:33 AM
Paul, would it be a good idea to hook up the volume control on the sex amp the same way as the Foreplay is hooked up ie. include a resistor in series with the wiper, and use a smaller K pot such as 5-10 k?
Bernie.
Offline keto
Reply #3 on: March 09, 2011, 07:24:26 AM
Thanks, Paul!
Tom Jones
Reply #4 on: March 09, 2011, 10:48:55 AM
Bernie.
The Foreplay burns off 10dB in that arrangement, which is a modified shunt-mode control. The virtue (if you can call it that) is that switch noise from bad contacts is less obtrusive. There is no switching with a potentiometer, so no virtue - and SEX needs the gain unless you have a really high-output source.
