western electric 100f
dgb · 8391
Offline dgb
on: March 20, 2011, 03:58:50 AM
i have a pair of these (http://www.radiomuseum.org/r/western_el_100_f100_loud_speaker.html)
that i wish to use with my mp3 player/sansa fuze.
one has a defective r5. does anyone know what this is and how i might obtain one.
i post here only because i follow this forum daily and know how many sharp people there are around here.
tia
Offline howardnair
Reply #1 on: March 20, 2011, 05:34:08 AM
interesting??? velly intillestingk!!!!! who said that? colonel klink????-or laugh in -well anyway r5 could be a resistor-but that is a vague description of its ailments -it may need a lot  more than that- does this have rca jacks/jack -has it been updated- if the capacitors are original do not plug it in--it will not last long if you do--that is a cool idea for small room or tabletop sound--gives me ideas--give us more info--are able to work on this thing????
Offline dgb
Reply #2 on: March 20, 2011, 09:12:31 AM
Offline howardnair
Reply #3 on: March 20, 2011, 10:54:13 AM
dgb-F3 is a ballast tube--i had to search--essentially a resistor in a glass or metal tube with a octal base--i can see your confusion-as i was very confused looking at the pics in your first post showing all the tube bases from underneath--the following link is said to be a schematic-hand drawn-it may be the multiple resisitors on the left of schematic-not sure-pilot light would be a clue--seems to be several wires coming from the pins-turn it over and have a look see if that is so--
if you can't find one-you can simulate under the chassis easily enough-just not sure of the wattage
http://www.agabengalcats.com/chad/we100f.jpg
Offline howardnair
Reply #4 on: March 20, 2011, 11:05:13 AM
Offline dgb
Reply #6 on: March 20, 2011, 02:11:14 PM
howardnair,
thanks so much for this info. i do appreciate it.
onward...
Reply #7 on: March 20, 2011, 04:56:41 PM
A quick look shows that there are equivalent tubes with double-voltage heaters - 50L6, 50Y6, ans 12SL7. Wouldn't that eliminate the need for a large ballast? Throw in a 150mA/6.3v pilot light and you are at 118.3 volts, close enough to 120v. Just a thought.
Offline Oldcrank
Reply #8 on: February 29, 2012, 08:37:27 AM
Here is the schematic for the Western Electric 100f Amplifier:
Look in the TCI Library for BSP 024-101-100, Issue 1.
newbielink:http://www.telephonecollectors.info/index.php?option=com_docman&task=doc_details&gid=5754&Itemid=2 [nonactive]
Offline dgb
Reply #9 on: February 29, 2012, 08:55:54 AM
thanks for the link "oldcrank",
i thought this thread was long dead.
i did redo a stereo pair for my flac player.
fun to think of something 60odd years old being
repurposed for high tech.
Offline chrisby
    • commercial site:
Reply #10 on: February 29, 2012, 10:38:33 AM
arte johnson on laugh-in IINM
Chris Bobiak
Victoria BC Canada
you don't really believe everything you think, do you?
