Goldpoint wiring help
pro_crip · 5539
Offline pro_crip
on: March 22, 2011, 08:51:00 AM
I've started doing the STP wiring to the selector switch and attenuators, all Goldpoint. The problem is I don't know what goes where. Do I string all the right side input jack ground lugs together into the c hole on the "right" side of the the input of the switch and run the center jack to their respective hole on the selector.Then how do I wire the output to the attenuator (also Goldpoint)?  How do I figure out where left, right, input and output are on these buggers? Yes, I've already emailed Arn over at Goldpoint asking for help, I thought a shotgun approach might be a better approach. I'm knackered, off to the land of nod. Thanks for listening.
Rich
Richard J Feldman
Tune down, smoke up
Offline Maxwell_E
Reply #1 on: March 22, 2011, 01:37:32 PM
Goldpoint has a lot of helpful schematics for all the different volume/selector wiring options.
The Passive Preamp and Passive Line Stage diagram sounds the most like what you'll be doing.
http://www.goldpt.com/diy.html
Max Tomlinson
SEX amp, Tode guitar amp
Reply #2 on: March 24, 2011, 08:20:59 AM
http://www.bottlehead.com/smf/index.php/topic,699.0.html
This thread has build pictures using the Goldpoints. I found looking at it useful when I upgraded my attenuators.
Offline debk
Reply #3 on: March 24, 2011, 01:45:09 PM
Rich
I sent you a PM with some of the details.  Contact me if you still ahve questions
Debra
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
