Replacing power supply resistors with chokes
pro_crip · 35583
Offline debk
Reply #15 on: April 03, 2011, 04:17:48 AM
It looks like there is a space just to the left of the power transformer (looking from the top) it may just fit.
Deb
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Offline Paully
Reply #16 on: April 04, 2011, 05:32:21 AM
Forgive me if this is a really silly question but I am curious.  When talking about shielded wires the ones we use for building from bottlehead seem to have an inner foil.  If I wrap the wires of the choke in aluminum tin foil and then put shrink unsulation over it to make sure it can't short anything out, am I providing extra protection from hum pick-up?
Offline Beefy
Reply #17 on: April 04, 2011, 08:29:14 AM
No. Aluminium provides virtually no protection against magnetic fields.
Offline Paully
Reply #18 on: April 04, 2011, 08:38:56 AM
Oh well, thanks for the response!
Offline Paully
Reply #19 on: April 05, 2011, 04:36:41 AM
I don't know.  12-24" maybe?
Offline debk
Reply #20 on: April 09, 2011, 05:22:52 PM
I put a Triad C-7X choke into my Eros.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi566.photobucket.com%2Falbums%2Fss102%2Frktdoc%2FEros%2FP1000344-2.jpg&hash=47ff975ce1ee5df69981c198117076d71db8b222)
Fairly easy to do, just had to drill two holes, remove the resistor and solder in the two leads.  I also ran a ground wire from a solder lug I placed on one of the screws to the star ground lug on the power tranfo.
It did make a large difference in the sound.  It sounds "brighter" and maybe more detailed now.  I originally had a rear firing super tweeter on top of the speakers to add "a little twinkle to the high end".  After the choke was installed I disconnected the super tweeters, it was just to bright.  I may try and add a L-pad to the super tweeters to tone them down a bit, or play with the capacitor connected to them.
No problem with any 60Hz hum being picked up.
First impression is that I like the way it sounds with the choke.
Debra
Debra K
Eros 2Phono amp
Roon Nucleus
Jager speakers
Reply #21 on: April 09, 2011, 05:52:08 PM
Cool! Thanks for documenting this; we all learn when one person experiments. The beauty of community....
Reply #22 on: April 10, 2011, 01:53:53 AM
Debra,
Does the plate still fit within the base with the choke mounted there?  It looks awfully close to the edge.
« Last Edit: November 08, 2011, 01:42:54 AM by Grainger49 »
Offline debk
Reply #23 on: April 10, 2011, 02:30:41 AM
Yes the plate still fits on the base.  The perspective in the photo makes it look like it hangs over the edge.
I could have mounted it a little closer to the PCB.   I had to sand down the inside of the wood case a couple of mm.  Forgot to take into account the lip the top plate sits on.
Debra
Debra K
Eros 2Phono amp
Roon Nucleus
Jager speakers
Reply #24 on: April 10, 2011, 02:34:43 AM
Thanks.  I own a rotary rasp that makes quick work of nibbling out wood.  I'll take it to Paul's house.
Offline debk
Reply #25 on: April 10, 2011, 02:45:27 AM
I just used a Dremel tool.  It took only a few seconds to sand the area down
Debra
Debra K
Eros 2Phono amp
Roon Nucleus
Jager speakers
Reply #26 on: April 10, 2011, 06:57:37 AM
Hey Deb, do you have a scope? Your description of the sound makes me curious to see if maybe the choke is picking up some high frequency interference that makes the sound seem brighter. Might be interesting to look at the noise floor and see if there are any really high frequency spikes riding on it, like maybe up in the MHz range.
Offline debk
Reply #27 on: April 10, 2011, 08:19:27 AM
Sorry, I don't have a scope.  probably should look into getting one
Deb
Debra K
Eros 2Phono amp
Roon Nucleus
Jager speakers
Offline debk
Reply #28 on: April 10, 2011, 10:06:04 AM
Actually I do kind of have a scope.  It is the DPScope, a USB scope that goes out to about 1MHz.  I have not used it in a few years and forgot about it.
I used it connected to one of the outputs with no input into the Eros
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi566.photobucket.com%2Falbums%2Fss102%2Frktdoc%2FEros%2Feros4.gif&hash=1d022918a3695c5de5ef3a46985e76d7f96f8d75)
Since we were looking for possible high frequency spikes, I set the scope to do a FFT
40Hz/div Shows a 60Hz spike
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi566.photobucket.com%2Falbums%2Fss102%2Frktdoc%2FEros%2Feros1.gif&hash=7d251a01c6e07d0e1904d0adc6446746a79baefa)
20KHz/div
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi566.photobucket.com%2Falbums%2Fss102%2Frktdoc%2FEros%2Feros3.gif&hash=2c2c3376955f457beb6aadaeae54c6718cbd0335)
Don't know if this data is meaningful or not, or if I even made the measurements properly.
Probably should get a real scope with a higher bandwidth.
Debra
« Last Edit: April 10, 2011, 10:12:18 AM by debk »
Debra K
Eros 2Phono amp
Roon Nucleus
Jager speakers
Reply #29 on: April 10, 2011, 10:29:10 AM
Debra,
1M Hz bandwidth is enough to tell if you have any oscillations.  And the software is more versatile than my Tek digital storage scope.  Your FFT shows no high frequency noise.  I am surprised that the FFT shows such high 60 Hz component, but that is the advantage of it versus the scope trace itself.
« Last Edit: April 10, 2011, 03:22:25 PM by Grainger49 »
