Is this a short circuit or normal?
Gauss · 3189
Offline Gauss
on: April 03, 2011, 02:35:43 PM
I started building my crack. I'm at page 19. While I read for shorts with my multimeter I found pins 4 and 5 from the transformer to read as a short and 0 ohms. Is this a normal reading because of the transformer nature or do I have a short circuit that must be fixed?
Reply #1 on: April 03, 2011, 02:55:33 PM
Hi,
That is the filament heater supply, and yes, it should be very close to a short circuuit on the PT3 transformer.
You should be goo to go.
Reply #2 on: April 03, 2011, 02:57:55 PM
Well, the last step on page 19 is to ground transformer terminal 4.  You should read close to zero ohms between transformer terminals 4 and 5 or zero from 4 to ground and near zero from 5 to ground.
