How much DC offset is normal for this amp?
sbelyo · 4933
Offline sbelyo
on: May 02, 2011, 07:46:55 AM
Hi All...
I completed my crack last night and I must say it is a fantastic kit for the money.  I am very impressed with the sound even after only 1 hour of break in.
Now, here's the question.  I am getting around 20 - 30 mV DC on the left and right output.  They will both float anywhere between -12 to 40 mV dc if you sit there and watch with a meter.  Is this an acceptable value and what would you normally expect to see with this amp after it has warmed up?
Reply #1 on: May 02, 2011, 08:42:23 AM
Shawn is checking a stock Crack as I type this, and we'll post our results.
Offline sbelyo
Reply #2 on: May 02, 2011, 08:57:08 AM
Thanks Doc...
It sounds real good by the way.
I did find a wiring error during my voltage checks where I had accidently connected B6 to U10 instead of U9.  This sent 90 Vdc to the left output.  When I corrected it everything fell back in line.
To the best of my knowledge this shouldn't have damaged the left output cap, am I correct?
Reply #3 on: May 02, 2011, 09:24:56 AM
That cap should be fine. We just looked at a stock Crack with Speedball and a couple of different tubes. The behavior is consistent, but not the offset. It's not really a steady DC voltage but a randomly (slowly) shifting voltage that wanders from around 0 to 30mV, most of the time below 10mV of shift. My hunch is that it is something the 6080 is doing and as far as I can tell it is benign - too small to hurt anything and too slow to be audible.
Offline sbelyo
Reply #4 on: May 02, 2011, 09:36:10 AM
Thanks doc...
That's exactly what mine does.  I won't worry about it.
I'm used to my other solid state circuits where I trim the offset down to 0.5 mV
Reply #5 on: May 02, 2011, 12:09:48 PM
I expect that leakage in the electrolytic output capacitor plays a part. Electrolytics are always a bit leaky. The voltage should drop a lot when the cans are plugged in.
Offline sbelyo
Reply #6 on: May 02, 2011, 01:04:10 PM
I thought about that in the back of my mind, I'll have to measure with phones plugged in
Offline JC
Reply #7 on: May 02, 2011, 01:16:01 PM
Yup, that's the thing to do.  Electrolytics tend to wander around a bit if they have no load path, even in power supplies.
« Last Edit: May 02, 2011, 01:17:35 PM by JC »
Jim C.
