Brainstorming Paramount upgrades
johnsonad · 10984
Offline trioid
Reply #15 on: July 20, 2011, 03:53:04 PM
Hi Brillo
3.3 uF, 630 V Solen
Jim
Offline porcupunctis
  • 0D3
Reply #16 on: August 09, 2011, 06:38:46 PM
I realize this is a pretty lo-tek solution but what if you just added another switch.  Like most tube-based guitar amps use.  One is on-off and the other is standby-on.  So if you turn the amp on with the other switch in standby, all you really do is supply the heaters so the tubes can warm up.  After several minutes of warm-up, you flip it out of standby.
Not much can go wrong with a good switch and their easy to replace.  Relays and delay circuits are another matter and can get flaky on you.
Randall Massey
Teacher of Mathematics
Reply #17 on: August 10, 2011, 05:43:51 AM
The soft start kit does this for you automatically. Don't really need that much heat up time, 30 seconds is adequate.
