DIY pcb
John Roman · 6835
Offline John Roman
on: May 16, 2011, 11:14:22 AM
I've gone off the deep end and am considering making some boards for my crossovers. I've just started looking online. Any ideas on a site to check?
regards, John
Regards,
John
Offline corndog71
Reply #1 on: May 16, 2011, 01:54:04 PM
I've found hard-wiring to get the job done just as well.  Although it does make it harder to tweak.  I used a hot glue gun to help hold everything together and to secure it to the cabinet.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2Fx-ls%2520upgrades%2FIMG_2157.jpg&hash=a14f434361e427fc26000a0c91de6c2a639945a2)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2Fx-ls%2520upgrades%2Fecafc095.jpg&hash=19d8bf6daaaaac9438cc414f842f53a116e25214)
« Last Edit: May 17, 2011, 07:03:17 PM by corndog71 »
Rob
Reply #2 on: May 16, 2011, 03:11:44 PM
I hadn't thought of this when I looked at this the first time.  You have more power at the speaker than anywhere in your system.  The traces on a board should be wide and unusually thick to pass the power properly.  Otherwise wire is better.
« Last Edit: May 17, 2011, 12:57:28 AM by Grainger49 »
Offline Maxwell_E
Reply #3 on: May 16, 2011, 03:59:20 PM
In my experience, homemade boards are at best temporary. I would bread-board a cross over, tweak it, and find your favorite flavor. If it were me, I would then get some terminal strips like what's in all the kits and screw them down to a chunk of wood and solder all the pieces point-to-point.
The lab I work in has a $15k mill for making circuit boards, and even then they are just made to be prototypes. I would stick to wire and PTP connections.
Max Tomlinson
SEX amp, Tode guitar amp
Offline John Roman
Reply #4 on: May 17, 2011, 06:21:56 AM
After looking around a bit I agree with your conclusion. The experience might be fun but I'm too picky to accept a shoddy result. Thanks for the insight.
John
Regards,
John
Reply #5 on: May 17, 2011, 09:48:44 AM
There are many places that will make prototype boards for you. But they are expensive unless you buy many identical boards - in practice you'll wind up paying $5 to $10 per square inch, and you'll get several copies - more than a stereo pair.
Offline rif
Reply #6 on: May 17, 2011, 11:32:19 AM
Would these help? Disclaimer: I know very little about crossovers, and nothing about this product. But it sounds like it may be what you are looking for and I've had good experiences with PE.
http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=197&CFID=40260858&CFTOKEN=3283877
-david
Offline electrovice
Reply #7 on: May 17, 2011, 03:14:26 PM
How about using turret terminals on a piece of perf board or PC board. The copper side of the PC board could be used as a ground plane.
There are a lot of vendors for turret terminals on eBay.
John
http://shop.ebay.com/i.html?_nkw=turret+terminal&_frs=1&_trksid=p3286.c0.m359
Offline Mudhiker
Reply #8 on: May 17, 2011, 06:08:48 PM
I etched my own boards in High school.  They weren't perfect, but it's not that big of a deal, and a steady and careful hand can make a good product.  Sourcing the chemicals is the toughest part, I doubt they have them at Radio Shack any more.
Isaac Gorton
Offline InfernoSTi
Reply #9 on: May 18, 2011, 02:44:10 AM
A nice piece of wood can make a good crossover platform.  Perhaps maple would be nice?  Here are my crossovers:
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.hawthorneaudio.com%2Fphotos%2Falbums%2Fuserpics%2F11473%2Fphoto-273.JPG&hash=810152c0aa460866c725554621a102208c28c873)
John
John Kessel
and lots of room treatments!
Offline VoltSecond
Reply #10 on: May 18, 2011, 05:31:58 PM
If you don
« Last Edit: May 18, 2011, 05:38:24 PM by VoltSecond »
Offline John Roman
Reply #11 on: May 21, 2011, 07:36:31 AM
Here's how the network looks thus far. I've just been arranging and re arranging components until I come up with something I'm satisfied with. At this point the physical layout has taken somewhat of a backseat to the layout in terms of maintaining better distances between inductors. If this is going to be exposed, even on the back side of the baffle it must look clean and even enhance the overall look of the speaker. Any thoughts, you know like take another prozac, get a life or ?????
John
Regards,
John
Reply #12 on: May 21, 2011, 12:03:56 PM
The inductors are too tightly coupled and will interact. It will never be perfect of course (5 coils and only three orthogonal directions in this universe!) but I'll suggest a few small changes that will help.
I'll number the inductors in your picture this way:
   3
                 4      5
flip 1 so the hole points up (like 4) to make it perpendicular to 3
rotate 2 so the hole points down, towards 4. That makes it perpendicular to 1 and 2.
rotate 5 so the long axis is left/right.
Move 4 and 5 as low as you can.
This leave 1 and 4 parallel to each other but fairly well separated. 1 and 5 are also parallel but even better separated. And each component is pretty much in the same place as you have documented.
Offline John Roman
Reply #13 on: May 21, 2011, 08:36:59 PM
Thanks Paul,
How's this look?
John
Regards,
John
Reply #14 on: May 22, 2011, 02:05:04 PM
You got it. Looks good to me.
