SEX 2.1 Manual Mistake
Oberst Oswald · 21459
Offline Oberst Oswald
on: August 21, 2011, 03:30:31 PM
On page 34 the written part for caps 22uf 450v says to "attach the striped end to 11U and non striped end to 12U".  The picture shows different and the same on the B side 21U & 22U.  I would say the picture is the correct way.
X-Fi > Stello DA100 > BeePre > SEX 2.1, Beta 22 or Bijou.    Paramounts > Extended Foreplay III > Thiel CS2
Stax SR-Lambda with SRD-7/SB
Denon D-7000
Audez'e LCD-2r2
Sennheiser HD 800
Reply #1 on: August 22, 2011, 02:47:12 PM
Yes, thank you, those terminals are indeed reversed in the text. It should be assembled as shown in the picture.
Reply #2 on: August 22, 2011, 04:37:08 PM
That is our reality check. The manual uses pictures taken during assembly of the production prototype, so you know the pictures are correct - we have tested the prototype before anything actually ships! (On the rare occasion there is a change, photoshop comes to the rescue - but we work hard to make sure the pictures are correct.
Offline Todd R
Reply #3 on: December 21, 2011, 11:46:12 PM
I also found a mistake.
Installation of plate chokes and output transformers: You are never told to install the ground tabs on 2 of the screws.
