Quad II set-up Q's
tpatton · 13022
Offline tpatton
on: September 27, 2011, 05:11:16 AM
For use along with my Bottlehead Paramour II's and S.E.X. amps, I just got a pair of antique Quad II's, and need answers to three questions: (A) how do I wire up the RCA jacks I'll install, (B) how do I set the amps for 110-120 VAC, instead of the 220-240 VAC they now seem to be set for, and (C) how do I set the amps for 8 ohms speakers, when they're standardly set for 15 ohms speakers?  I hope my getting the Quad II's isn't taken as disloyalty to, or dissatisfaction with, Bottlehead amps--I don't expect the Quad II's to equal the Bottlehead amps, but I'm old enough to have had a pair of Quad II's over 50 years ago, and the pull of nostalgia is very strong.
Offline John Roman
Reply #1 on: September 29, 2011, 04:50:28 AM
I wish I could be some help but have no experience with Quad. I'm sure a search of the net will provide some answers. Keep us posted.
Regards,
John
Offline tpatton
Reply #2 on: October 01, 2011, 04:55:56 AM
Keith Snook in the UK has been incredibly helpful, very generous with his time.  Check out his website for a lot of interesting stuff: www.keith-snook.info.  (If that isn't right, I'll correct it.)  I now know how to set up the Quad II's for 4 to 8 ohms speakers, and have learned that I'll have to use external step-up transformers since their power transformer handles 220-240 VAC only.  But I can live with that.
Reply #3 on: October 01, 2011, 07:04:28 AM
May I suggest, if you can find the right product, that you consider getting a step-up transformer with some way to adjust the output voltage? Not necessarily a complete variac, which can get expensive, but there must be some with a few taps. The Quad is old enough that power line voltages are probably higher than they were when it was designed - they seem to have been drifting upward for a century, with no end in sight.  Just a thought.
Offline tpatton
Reply #4 on: October 01, 2011, 11:03:04 AM
In reply to Paul J's useful suggestion, the Quad II itself has three choices of voltage: 190-209, 210-229 and 230-250.  I was going to use the middle range--does that sound right?  Or should I be conservative and use 190-209?  I'm replacing a lot of resistors and film caps, and could use advice on which caps deserve replacement.  The layout is very obscure compared with the neat clarity of Bottlehead gear.
The schematic can be found here: http://www.keith-snook.info/Schematics/QUAD%20II%20Schematic.pdf.
Reply #5 on: October 01, 2011, 12:10:27 PM
Fascinating! Those guys were just too clever for their own good ...  :^)
Sonically, the coupling caps C2 and C3 are probably the most important. But look at the "Note:" on the circuit! Perhaps Mr. Snook has some other notes on this? You would probably need some auxiliary capacitors if you changed the originals. Any idea what the originals are, and whether they are actually in need of improvement?
The power supply capacitors C6 and C4 would probably be worthwhile, and the cathode bypass C5 - also from a reliability standpoint since they are apparently electrolytics. Note also the special current rating on the power supply input capacitor C6. A modern electrolytic rated for switch-mode (high frequency) power supplies would most likely be OK, but a film cap would be superior and might be available in a small enough package these days.
I have no idea how sensitive the screen-grid cap C1 might be - this is the first time I've seen such an arrangement. It should be easy to swap out and you can listen for any difference - I'm just not prepared to guess what if any difference you might hear.
Thanks for sharing the circuit.
Offline JC
Reply #6 on: October 01, 2011, 04:02:08 PM
Personally, I think I would get my step-up transformer and measure the Voltage coming out of it.  Set the input Voltage on the amp accordingly.
Step-ups are not necessarily precise, and this will also account for your line Voltage.
Jim C.
Reply #7 on: October 01, 2011, 04:44:08 PM
Yeah, Jim has a good point. I just bought a 240V true step up transformer for the lab and it runs more like 250V into our stuff, but it works fine -
http://www.ebay.com/itm/230660480158?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
A few months before I had purchased what I thought was a reasonably priced (maybe $65? I can't remember) Chinese 120-240V "step up" from a high feedback ebay seller and, frankly, it is a total piece of shit.
http://www.ebay.com/itm/250772700076?ru=http%3A%2F%2Fwww.ebay.com%3A80%2Fsch%2Fi.html%3F_from%3DR40%26_trksid%3Dp3984.m570.l1313%26_nkw%3D250772700076%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
 It's so noisy that it is unusable for audio. It sits in the hallway at work while I screw up the courage to put it where it belongs, in the dumpster.
Offline tpatton
Reply #8 on: October 02, 2011, 04:37:30 PM
Thanks everyone for your continuing help.  As to Paul J's suggestions, I can't find either C4 or C6, but can see the two points that C6 connects to, and was planning a film cap bypass there.  I'll see if I can do the same for C4.  Keith Snook wants good caps for C2 and C3, which I'll do, and wants "a 160V extended foil polystyrene capacitor for C1".  I don't know what that is, but would an Obbligato Gold Premium, for example, do?  Or would something cheaper do as well?  C5 is in sight and I was planning a Nichicon, 22 uF, or the like, bypassed with a 1 uF Solen.  Should I spend more there?
I was planning to do what Jim suggests on the transformer: measure and set the amp accordingly.  I hope my inexpensive step-up transformers prove to be okay--ordered on eBay but not here yet.
I'm going to change every resistor in sight, may of which don't measure very close to proper values.
Thanks again for all the help--I consider this now to be a joint project, and will report how it comes out.
Offline John Roman
Reply #9 on: October 03, 2011, 05:07:07 AM
Just checked out the snook website. Looks like that is a great resource. How does yours compare to what snook says. In other words, do you have a good one?
Regards,
John
Offline tpatton
Reply #10 on: October 03, 2011, 07:15:30 AM
I don't have a pair that look remotely like Keith's beautiful restorations, but when my step-up transformers reach me, I'll be ready to see how they sound, if at all.  I've just ordered from pcX 22 resistors, replacing all but a 3W 180 ohms resistor in each chassis, and a bunch of good film caps and two electrolytics, and if I get any sound at all in the present "as is" state, I'll proceed to upgrade and see how much that helps.  I wonder how hard, and how expensive, it would be to replace the 220-240 VAC power transformer with a 110-120 VAC one.   I'd love not to have to use step-up transformers.
I also wondered if some clever Bottlehead would be able to get these amps working again in case they don't sound good even after all my efforts.  And even change the power transformer if I can learn how to do that.  I'd expect to pay for this service, of course.  Someone on eBay is willing to repair a single Quad II for $195 plus $52 shipping back to me, and with my shipping to him, that's too expensive, and would duplicate all the component changes I'll make--so I'm hoping for a better rescue than that.
Offline John Roman
Reply #11 on: October 03, 2011, 12:03:53 PM
Might be difficult to trust an Ebay contact, I'm not sure. On the other hand their are several BH's I'd definitely trust. $250 for the job really doesn't sound that bad. What about Snook?
Regards,
John
Offline Jim R.
  • Blind Bottlehead
Reply #12 on: October 03, 2011, 02:29:14 PM
PJ,
Where does that screen grid cap connect?  Wondering if this is the ame cap connection that Deccware calls alternatively the "Christmas Comes Early" or Hazen Grid Mod"?
-- Jim
Reply #13 on: October 03, 2011, 02:49:59 PM
Jim, the phase splitter is a pair of EF86 in paraphase. Each screen is fed from a 1 meg resistor. The capacitor is between the two screens - there is no cap to ground or to the cathodes, which you might normally expect. The cathode bias resistor is also unbypassed, and the feedback goes there, i.e. shared by the two tubes.
Offline tpatton
Reply #14 on: October 04, 2011, 08:35:39 AM
My step-up transformers arrived and I could finally hear what the Quad II's sounded like, with luck.  I didn't have great luck: a few minutes of good-sounding music from one amp, then switched to the other and a transformer fuse blew immediately.  Switching back to the first amp, it played for less than a minute before a transformer fuse blew.  These are 200W transformers.  My homemade) cord is fine, transformers work with nothing plugged into "240 Out", so the problem must be in the amps.  All I've done is to install RCA jacks, the center (for the pin) going to Jones plug socket #2, called "Input" on the circuit diagram, where the RCA jack shell goes to ground.  Resistor R1, 1M ohms, is still in place between socket #2 and ground.  I can't see that I've done anything bad there, getting the RCA jack installed.  My question: where should I look for the trouble that's causing the transformer fuses to blow?  Not easy to answer from a distance, I realize--but with so much expertise available on this Forum, why not try?
I've ordered replacements for all resistors but the 3W 180R ones, which read close between the two chassis, and replacements for film caps C1, C2, C3 and more film caps to use as bypasses wherever I can find the two connection points for out-of-sight electrolytics.  Maybe making all those changes will eliminate the blown fuse problem without my ever discovering what it was.  Hope springs eternal.
