6CG7 alternatives
Ritchie · 10764
Offline Ritchie
on: October 05, 2011, 12:32:26 PM
My ext. foreplay is set up for 6CG7's. What other tubes can I try as direct plug-ins without any circuit wiring changes besides heater supply for certain tubes.
I'm assuming I can try 6N1P's, I am curious how these would sound.
Ritchie
Ritchie M.
crack/speedball as preamp,linn lp12 w/radikal/keel/urika phono, linn majik 4100 active monoblocks,linn majik isobarik speakers(active).
Reply #1 on: October 05, 2011, 02:32:39 PM
You cannot change the tube type without checking and usually adjusting so that the plate voltage is correct. Adjusting means changing the bias or the plate current; changing the plate current requires corresponding changes in the regulator supply current. 6N1P for instance would need a reduction in plate current to less than half the value used by the 6CG7 and 12AU7. You would also need to adjust the heater power supply resistor if you use tubes with different heater current draw.
Tubes that do not need such adjustments are mostly those with nearly identical mu and plate resistance. Occasionally there will be a tube with a different combination of plate resistance and mu which happens to work - from the numbers, it looks like a 6DJ8 might work, but I've never tried it.
Due to the low plate voltage used (around 75v) you want a tube with a mu less than 30. A 6DJ8 or 6N1P with mu=33 is pushing it. (By the way, the 6N1P is NOT a substitute for the 6DJ8/6922/etc. in spite of popular myth!)
The 6CS7 looks interesting; section 1 is identical to a 12AU7 but section 2 could run at 8mA for more powerful drive. Unfortunately the socket would have to be rewired significantly, along with the regulator currents.
« Last Edit: October 05, 2011, 07:00:17 PM by Paul Joppa »
Offline Ritchie
Reply #2 on: October 05, 2011, 02:38:54 PM
Thanks Paul,
I'll stick with the 6CG7, I always assumed the 6N1P was a replacement for the 6922 except for a higher heater current.
Wow! Nice to have so much knowledge on this forum.
Ritchie M.
