Regulated heater supply
Ritchie · 4013
Offline Ritchie
on: October 13, 2011, 10:38:46 AM
I was wondering if anyone has tried using a regulated filament supply for the Foreplay?
I believe if implemented properly it would have less ripple on the heaters and would maintain a constant voltage with any fluctuations in line supply.
Not sure if that equates to better sound or not?
Paul, did you guys try it and not like it or was it not in the budget at the price point of the Foreplay?
Ritchie
Ritchie M.
crack/speedball as preamp,linn lp12 w/radikal/keel/urika phono, linn majik 4100 active monoblocks,linn majik isobarik speakers(active).
Reply #1 on: October 13, 2011, 02:47:47 PM
Eros is the first, and so far only, Bottlehead product with regulated heater power.
Price is definitely an issue - Foreplay still has to live with its own history (it started at $99!). But probably the biggest issue is the power transformer. In order to use regulated DC heaters, you need a higher power transformer voltage, which makes it not work for AC heaters. Plus, of course, there is the regulator which needs a PC board and heat sink and tantalum caps and a few other parts. The Eros setup can supply only 1.3 amps, using the biggest PC board-mounted heat sink we could find - not enough for SEX, or for a Foreplay with 6SN7s, or for Crack or Smack - all of which use the same power transformer (another cost savings).
That said, we did (last year, I think) about upgrading Foreplay to use the Eros power supply. I wanted to increase the voltage and current in the tubes at the same time, for more headroom and more drive. I suppose that could become an upgrade kit option, too. But we've been trying other approaches to preamps, and some are very promising - enough that we hope to have a completely new preamp eventually. A full-dress Foreplay with C4S's, tube regs, higher voltages, and the Eros power supply would cost the same but not perform as well, so we're putting our efforts into the new design. For the same reason, while I'd love to upgrade the Seduction with Eros power and shunt regulation, it would cost as much as Eros but without delivering the performance to match.
Offline Ritchie
Reply #2 on: October 13, 2011, 03:54:08 PM
Thanks Paul, I might give it a try with a separate filament transformer.
Ritchie
Ritchie M.
