Biasing Help Wanted
mchurch · 3012
Offline mchurch
on: October 25, 2011, 05:38:23 PM
I have just finished helping a friend rebuild and early version of an Audio Mirror set of mono blocks using the 6C33 Russian Tubes. The mono blocks have biasing pots for the 2 tubes in each amp and I have the voltage information for the tube but I am not sure where to read the voltage to adjust the bias. Is there a particular pin for reading the bias? Cathode ? We cannot find any instructions and I don't want to install new tubes and kill them prematurely.
Any help and advice would be greatly appreciated I know this is not a Bottlehead issue but I figured that some of the resident tube experts might point me in the right direction.
Regards
Mike
Reply #1 on: October 25, 2011, 05:58:57 PM
There is not enough information in your post to provide anything useful, unless someone here already has these amps.
If we had a circuit, we could tell pretty easily. If we had the "voltage information" that you say you have, it might help. If you have any other information, that might help too.
