transfering lp's to reel to reel tape
howardnair · 2878
Offline howardnair
on: November 30, 2011, 04:14:42 AM
this is an idea i got from grainger-it should save wear and tear on your lp's
i have questions and more will arise as others are answered-
tape speed --7.5
best size reel for albums--this may be a personal preference as how one would like to catalog things
is it worth it???
grainger recommended dolby-
best kind of tape-- usrecording has rmgi tape--realdeal pro audio has quantegy-the rmgi is more expensive than the quantegy--usrecording media has a good faq section- tape time charts etc
thats it for starters
howie
Reply #1 on: November 30, 2011, 04:31:04 AM
My post from earlier:
Howard, up early, or late?
Let's see... dragging up my memories of selling audio gear in the 60s and 70s...
7.5 ips is enough for very good reproduction of an LP.  If you were making live recordings I'd suggest 15 ips.  IIRC, 1800' rolls are good for an album per side.  Aim at at least 30 minutes for an album.  I think 1800' rolls are 45 minutes at 7.5 ips.  That fits well on a 7" reel but the 10" reels just look so cool!
All tape has noise so a properly set up Dolby can reduce the noise.  All master recordings from back then used a professional Dolby for noise reduction.  If you can get a nice, four circuit Dolby that can be properly calibrated use it.  The Dolby process is a record and playback function, you probably know that.  The calibration adjustments are absolutely necessary for a linear response.  Not to mention your RTR should be biased for the tape being used.
I am not familiar with tape formulations available today.  I used a lot of top of the line Scotch and Maxell UD (in gold box) tape on my RTR machines.  (there is the picture of the Maxell man in my listening room)
The Akai have good response at high frequencies because of the Crossfield heads, like Tandberg.  I owned one Sony then two Teacs; liked the Sony loved the Teacs.  I also used and sold Revox, Tandberg and Crown.  I prefer the Revox over the Tandberg which had odd problems but get a Crown if you can find one.
You can find a lot of information for this on tapeheads.net, AudioKarma.org and if you want to dive off the deep end go to whatsbestforum.com.
Remove messageR
