SCREW SIZE
coca · 3584
Offline coca
on: December 04, 2011, 03:14:41 PM
I purchased a S.E.X. amp some time ago, but haven't gotten around to putting it together yet. I have miss placed some of the screws in the kit, and would like to know the length and diameter of the 4 screws that hold the power transformer cover on. Can anyone help?
Thanking you in advance.
Bernie.
Offline Jim R.
  • Blind Bottlehead
Reply #1 on: December 04, 2011, 03:27:24 PM
Bernie,
Assuming this is the 2.0 version, the bolts are 8-32 x 1-1/4"
Not sure if they're different for the new version of the kit as I haven't even opened that box yet.
HTH,
Jim
Offline coca
Reply #2 on: December 05, 2011, 05:56:05 AM
Thanks Jim. I'm sure it's version 2 as I have had it for about 4 years.
Bernie.
Offline Jim R.
  • Blind Bottlehead
Reply #3 on: December 05, 2011, 06:32:33 AM
Yes, that would be the right one then.
-- Jim
Reply #4 on: December 05, 2011, 08:36:18 AM
The manual has a typo, it's actually 1-3/4" long. Typo is in the parts list where it says 1-1/4", the correct size is in the text of the manual.
THe core of the power transformer is itself 1-1/4" thick. Then make allowance for the bell end cover, shoulder washers, lockwashers, chassis plate, and nuts - 1-1/2" is just not quite enough. Unfortunately 1-3/4" is quite a bit harder to find than 1-1/2" or 2".
Offline coca
Reply #5 on: December 07, 2011, 08:40:33 AM
Thanks guys. I will try and pick up the 1.75 inch bolts today. I have dropped off the chassis plate and trans cover to the plating company to have them copper plated. I like to use allen screws for the trans. cover, and they will have to be buffed as they are made of stainless steel.
Bernie.
Offline Jim R.
  • Blind Bottlehead
Reply #6 on: December 07, 2011, 08:45:17 AM
Hey Bernie,
Caswell Plating makes a stainless steel blackening solution and gel that's simple to use.  Just thinking black would look better against copper.
http://www.caswellplating.com
HTH,
Jim
