Seduction upgrades
berniebanks · 20527
Reply #15 on: December 14, 2011, 12:35:57 AM
James,
I don't see any pictures. (using Mozilla on my wife's laptop, I'll check my desktop)
Logged on using the desktop and Mozilla, no pictures.  Tried IE, no pictures.  Must be some setting.
« Last Edit: December 14, 2011, 03:55:46 AM by Grainger49 »
Offline bainjs
Reply #16 on: December 14, 2011, 12:49:00 AM
Grainger,
I can see the photos.
James,
What huge caps you have!
Joel Bain
Offline berniebanks
Reply #17 on: December 14, 2011, 12:57:23 AM
James
Thanks for posting the pictures they're really helpful. Thats a really nice build and I see what you mean about the size. At least I know there is space for them
Ive got some 0.1uf FT3 600v  for coupling and some 0.47uf FT3 200v for output on the way
Bernard Banks
Offline jamestw
Reply #18 on: December 14, 2011, 01:20:04 AM
Hi berniebanks,
If you want just 0.47uf FT3 for output caps, maybe get 400V or 600V is better.
I remember the original 0.47uf Orange Drop caps that came with kit, are rated 400V or 600V or so...
I believe you will very happy with the Seduction.
james
Offline jamestw
Reply #19 on: December 14, 2011, 01:33:05 AM
James,
Yep, FT3 caps are large indeed, but they are worth I can hear they make sounds different.
YMMV, try it to see if you like the sound.
thanks,
james
Offline berniebanks
Reply #20 on: December 14, 2011, 01:40:34 AM
Thanks James
I couldn't find any higher voltage 0.47uf on eBay and I guess if I could get some they would be massive.
I wonder if the voltage matters too much ?
Bernard Banks
Reply #21 on: December 14, 2011, 01:58:02 AM
James,
The Seduction power supply will never exceed the 200V rating.  Doc was using a standard capacitor.  I have used 200V KK Teflons in my Seduction for years.
I don't think that 0.47uF are available in 400V or 600V.  The largest I have seen in 600V is 0.22uF.  Not positive about 400V.
Offline jamestw
Reply #22 on: December 14, 2011, 08:20:19 AM
You are right, Grainger
that should be ok. as pictures I also use 0.1uf 200V FT-2s in parallel with 0.47 silver-oil caps.
I just thought the larger V rated the safer.
james
