Seduction hum (how much is normal?)
denti alligator · 85586
Reply #60 on: September 27, 2012, 03:57:01 AM
The first question is, do you listen to quiet music with the volume all the way up?  This is a sickness brought to us by magazine writers who report that the XXXXXXX was dead quiet in my system even with the volume all the way up.  It is not a real world test for most of us.  I listen to my Eros at 9:00, used to listen to my Seduction a quarter turn louder.  Eros has more gain.
The hum and buzz can be measured at the output jacks of the Seduction with the inputs shorted.  That will help put it in perspective.  Unplug the table, including ground, from the Seduction and the Seduction from the Quickie then set your meter to AC and measure.  There are low level noises that will always be there.
When you asked "Would adding a jumper between the two grounds help?"  Which two grounds were you speaking of?
The components of the noise can be seen on an oscilloscope.  I have one.  It doesn't really measure the RMS value of AC signals but will reveal the peak to peak voltage there.
« Last Edit: September 27, 2012, 04:09:44 AM by Grainger49 »
Offline denti alligator
Reply #61 on: September 27, 2012, 04:03:26 AM
I'm measuring 0.00.   ???
This is driving me bat crazy.
- Sam
Reply #62 on: September 27, 2012, 04:10:26 AM
Sam,
I edited the post above and were you measuring AC volts?
If you are bat crazy you must retire to the Bat Cave for a cold one.
Reply #63 on: September 27, 2012, 04:29:26 AM
Yes, measuring AC.
And yes, I sometimes listen to quiet music with the volume higher than usual. I find that with headphones I the pot ends up around 2/3 up. With quieter music it may go higher. And no, it's not totally blasting my ear off.
What's the next thing to try?  By connecting the two grounds I meant the one at the inputs/outputs/terminal strips and the one at the power/transformer/ground lug, which, as I said earlier, do not appear to be connected.
- Sam
Offline Laudanum
Reply #64 on: September 27, 2012, 04:43:37 AM
I know there are other things at play but just out of curiosity, what cartridge are you using?   On my Rotel table with Rega arm,  the Ortofon cart (Super OM10)  exhibited the most hum but it was still low level such that it was not heard at the highest I would listen.   On the Technics table I havent tried all my budget carts.   I use either an M97 or a Pickering XV-15 and again, whatever low level noise (hum) there is with the Crack volume cranked up,  I dont hear it with music playing or between tracks at my highest listening levels.    System = Table - Seduction - FPIII -  Crack.   Still need to make room to be able to add one of my small amps and some speakers.
Desmond G.
Reply #65 on: September 27, 2012, 04:48:40 AM
The TT is out of the equation. I've tried to isolate the source as much as possible, and it's really the Seduction that is bringing in the most hum/buzz. That is: I'm now using shorting plugs for the input.
- Sam
Reply #66 on: September 27, 2012, 05:15:26 AM
Sam,
The schematic doesn't indicate a connection.  Edit, it is between T10 and T20, according to the Bottlehead schematic.
Using a wire touch to the top plate and the ground buss.
« Last Edit: October 24, 2012, 05:23:54 AM by Grainger49 »
Reply #67 on: September 27, 2012, 05:46:11 AM
Will try it tonight. What do you mean by "touch to the top plate and ground buss"? I was just going to solder a piece of ground buss from one of the grounds to the other.
- Sam
Reply #68 on: September 27, 2012, 06:44:51 AM
Soldering is good.  Touching them together is faster.  There should be no voltage difference between them.  Touching will answer the question.  If it works, solder.
Reply #69 on: September 27, 2012, 07:57:04 AM
Looking at this thread, I am very confused about what is being discussed.
All Bottlehead gear uses a few techniques to minimize noise that I don't necessarily understand, but they seem to work for most people. First, all the pieces (except the Quickie) use a ground tab that connects the chassis to earth ground (3rd prong); this makes the basis for the star-ground. The signal ground is connected to the ground at one point. [EDIT: not 100% sure about this being a "single point"] In the Seduction, it's at the inputs
« Last Edit: September 27, 2012, 09:22:31 AM by fullheadofnothing »
Reply #70 on: September 27, 2012, 08:41:41 AM
Joshua,
Just looked at the manual, one wire from the RCA inputs' common lands on the ground plane.  Is there a connection between the chassis and the ground plane?  Are the inputs connected to the chassis and then through the ground plane?
The FP 2 had no connection between the signal common and the chassis/safety ground.  If noise persisted it was a common fix to jumper terminal 13 to terminal 14 which made that connection.
Even with Shielded Twisted Pair (STP) the signal common is usually, but not always, connected to the chassis of the sending and receiving pieces.  But the additional shield grounded to a chassis, a grounded chassis, gives additional noise abatement.  It sounds like this is redundant.  Won't hurt if it is redundant and might help if it isn't.
I think Sam and I are on the same page as I suggested connecting the incoming ground/safety ground to the known signal common.
Reply #71 on: September 27, 2012, 09:01:03 AM
Next, Grainger asked if Sam actually listened at a loud enough volume to hear the noise while listening to music. This is the crucial question-all systems make some noise, particularly when they are amplifying very small signals. If you are hearing the noise at full volume but never listening at that level, it does not matter.
Yes, this is key. But I'm persisting because the hum is loud enough that is CAN be heard in quiet passages or when listening to music with few instruments (jazz trios, quartets, folk, classical...). Even if it's not nearly as prominent, it's there. And I don't like it.
Granted, when listening through my speakers I can't tell the difference, unless I'm really cranking it--and then only in between tracks (but hey, that's still annoying). Mostly this is a headphones issue.
- Sam
Reply #72 on: September 27, 2012, 09:21:06 AM
I am working under the assumption that this discussion is based around the S.E.X. Am I right? Please be explicit here, I can only help if I know what we are talking about. My biggest source of confusion is in statements like this "I think Sam and I are on the same page as I suggested connecting the incoming ground/safety ground to the known signal common. " Very specific, yet completely vague.
Looking over the S.E.X., the chassis plate forms the main ground, it is connected to earth ground via the solder tab near the power inlet. The right input is connected to ground: black from the input goes to the pot, which goes to 12L, which is jumpered to 13L, which is a center terminal on the strip, therefore chassis, therefore ground. The left channel does not repeat this connection, most likely for noise issues of some kind (ask someone smarter than me for full details). Both channels are definitely connected to ground with the jumper from the headphone jack to 23L (again, center terminal). The specifics of this connection will vary depending on the jack used (varied yet again if the Impedance Switch Boards are used), but the connection is made regardless. I will edit my previous post since I'm not so sure about the statement about signal ground being connected only at one point.
As for the STP interconnects, they worked for me. I was having terrible hum with a coax based interconnect, I made something as described, my hum went away. Like I said, YMMV, but a few bucks at Radio Shack and a few minutes at the solder station can go a long way.
Reply #73 on: September 27, 2012, 09:39:06 AM
Touch to the top plate and the ground buss.
Is this vague?  This will hard wire the safety ground to the signal common.
As the title implies, it is a Seduction hum problem.
You didn't answer the question about the RCA input jacks and the ground plane.  Do you have a Seduction near to check?
My comment on STP was to point out that it doesn't remove the ground from signal common.  It just adds an additional shield.
Reply #74 on: September 27, 2012, 09:49:01 AM
Grainger, it's vague because when you are clearing up a systemic issue, it needs to be said which piece of gear you want to make the connection in. This issue is quite possibly caused by a difference in ground potential between two different pieces of equipment, so there are at least two ground busses and top plates in play.
You said "wire" which made me think you weren't talking about the Seduction, since the inputs aren't connected with wires, but directly to the ground plane (shell) and via resistor leads (pin). I've got my Seduction right in front of me. The ground post is not insulated from the chassis or the ground plane. The RCA inputs are not isolated from the ground plane. Grounded.
