Looking for a good vintage base for a sme 3009 , suggestions?
balancedtriode · 6525
Offline balancedtriode
I have a sme 3009 type 2 improved, it was mounted to a thorens td-125 LB but I decided to put a transcription arm on it due to the long base. trying to decide what base to buy for it, any suggestions? I am going to do research, just looking to be pointed in the right direction. I like vintage, wood bases, If it needs to be modded to accept the sme, that is fine.
any help would be appreciated.
thanks
-Coltrane
Thorens TD-160 Custom(rebuilt by me) with SME 3009 arm
Bottlehead Seduction
Extended Foreplay-III (build underway)
Stereomour Power Amp conversion (Heavily Modded)
Klipsch Cornwalls' with Vertical Horns
Reply #1 on: February 07, 2012, 03:28:48 AM
Coltrane,
You might go to the Audio Asylum and see if you get responses there.  There is a Vinyl Asylum that would be appropriate.
That said I'm not sure what you are asking here.  Wouldn't the vintage base go with the table more than the arm?
And as I typed "vintage" I thought that Audio Karma (.org) might be a vintage base kind of place.
Plus this gives you a bump.
« Last Edit: February 07, 2012, 04:05:53 AM by Grainger49 »
Offline Wanderer
Reply #2 on: February 07, 2012, 04:02:42 AM
I share Grainger49s confusion. Not sure how you are defining "base". Do you mean you are looking for a turntable to mount the SME 3009 on?
Knife edge pivot SMEs work/match nicely with a variety of similar period suspended turntables. Thorens (150, 160), Acoustic Research (THE Turntable, ES1, etc), Linn Sondek/Ariston. There are others.
                        Kevin R-M
« Last Edit: February 08, 2012, 06:14:26 AM by Wanderer »
Kevin R-M
Offline galyons
  • Geary Lyons
Reply #3 on: February 07, 2012, 08:16:26 AM
I have the same arm that serves occasionally on an Empire 298, Thoren4 150 and Thorens 124.  A good arm for high compliance carts. Should match well with any quality 60's TT.
Cheers,
Geary
