Bottlehead Kits
Crack
Speedball transistors
xcortes
3003
xcortes
Sr. Member
February 02, 2012, 11:13:10 AM
Why does the CF C4S on the Speedball upgrade use different transistors than the "regular"? Just when I though I understood how to design a C4S you throw a curve ball!
Xavier Cortes
Paul Birkeland
Global Moderator
Hero Member
Re: Speedball transistors
Reply #1 on:
February 02, 2012, 02:23:09 PM
Hello Xavier,
The TIP50 is essentially an MJE-340 that is just a little bit beefier. Also, the larger size of the case helps to get rid of the heat more efficiently.
xcortes
Sr. Member
Reply #2 on:
February 02, 2012, 06:25:34 PM
Hi Paul,
That's what I figured. More so since the values of resistors seemed to behave identically.
But I thought I'd rather ask.
On to building my modified Crack to drive my 800 ohm speakers then.
Xavier Cortes
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
February 02, 2012, 06:28:22 PM
I'm totally excited to see the results of your project. This has been one of those things that has been discussed quite often, but never followed through.
Bottlehead Kits
Crack
