Straight 8 - the original Bottlehead speaker kit
Doc B. · 156134
on: October 15, 2009, 02:24:13 PM
This was great bang for the buck speaker, but difficulties with the supply of various parts forced it onto retirement. Perhaps the coolest part was the cabinet kit that assembled like IKEA furniture. Unfortunately the original plans disappeared when we lost an old hard drive and somehow we never backed them up! If anyone has the original instructions and can send scans we will post them here.
http://www.bottlehead.com/straight%208/straight_8.htm
« Last Edit: July 22, 2016, 09:54:19 AM by Doc B. »
Offline Geek
  • Tube Geek
    • Classic Valve Design
Reply #1 on: October 15, 2009, 03:33:06 PM
Sure is a sharp looking unit.
Sorry to hear of your data loss.
Cheers!
-= Gregg =-
Ratings are for transistors, tubes have guidelines.
Work: Classic Valve Design
Home: GeeK ZonE
Offline Wrinkles
  • Michael
Reply #2 on: October 15, 2009, 03:53:10 PM
Doc,
Could you post the last crossover designed for the straight 8s? I still love these speakers.
Michael
Reply #3 on: October 15, 2009, 04:06:56 PM
Quote
Actually I did, sort of - at least for the stock tweeter. Follow the link to the Straight 8 page, and it will direct you to a page with info on the last crossover.
We did a couple of other iterations, one with a horn tweeter and one with an Aurum Cantus ribbon tweeter. I think the info is probably in the old forum archive. It would be great if someone tracked it down. I would be happy to post the info here if you send me a link to the original post.
Offline booangler
  • My first love! Not Me... Fishing!!!
Reply #4 on: October 16, 2009, 02:10:38 AM
Hi all,
I have been thinking about building the ART Array as a Winter Project. I was surprised to see how similar the Straight 8 and the ART seems to be. I am wondering if the Climax crossover might work in the ART?
Alan
« Last Edit: October 16, 2009, 08:52:02 AM by booangler »
The joy of music should never be interrupted by a commercial - Leonard Bernstein
Denon POA | PJCCS Quickie | Hagerman Bugle | SOTA Sapphire w/ Grado Gold | B&W 602
Reply #5 on: October 16, 2009, 05:10:25 AM
Possibly a cousin, but I'm afraid the DNA of the drivers is enough different that it would need it's own crossover design. The Straight 8 crossover addresses some warts that are peculiar to the drivers we used, and thus an optimized crossover for the ART array would need a crossover that addresses it's drivers' peculiar warts. Might be close, but not optimal.
Reply #6 on: October 16, 2009, 07:00:55 AM
...I was surprised to see how similar the Climax and the ART seems to be. ...
(Of course you mean the Straight 8, not the Climax.)
Towards the end of the development chain of both designs, I wound up targeting the same acoustic crossover for both Straight 8 and Climax - fourth order Linkwitz-Riley at 3150Hz. In all cases (tweeters and woofers, Straight 8 and Climax) the individual drivers have responses that are not flat so the crossover electrical response plus the driver response works out to the target acoustic response. Therefor none of these crossovers are suitable for different drivers.
Here's a rundown on the various drivers:
Straight 8 midwoofers - the original drivers had a curvilinear cone; they were replaced without warning by the supplier with straight-sided cones at some point. This made a difference in the treble response. Various thin coatings were used on the woofer cones to damp the very high frequency ringing (an octave or two above crossover); the best of the coatings was discontinued - again without warning - by the manufacturer. The most recent published crossover is the best we have come up with.
Climax midwoofers - again, the original Eminence driver was discontinued. It had great promise, though the small excursion meant it needed a subwoofer like the SEXy Speaker design. The published crossover was quite good, matching the L-R amplitude and phase remarkably well to more than an octave past the crossover point. These were tough drivers and needed extensive break-in to perform at their best.
Straight-8 dome tweeter - this titanium dome has some problems with limited excursion (making it more fragile than the very sturdy woofer array) and a 20kHz resonance, but was otherwise very clean. The most recent published crossover included a 6dB trap to kill the resonance. The limited excursion makes it a little rough when pushed too hard, but at normal levels it works quite well. (Normal levels means Mahler is OK but Nine Inch Nails is not.)
Climax horn tweeter - This little Selenium is very tough, but it needed a lot of help. The response is far from flat, and the horn mouth reflections and cabinet scattering are quite severe. The crossover is fairly complex, and very different from a classical theoretical crossover. And the horn modifications described in the published design are essential to use in conjunction with the crossover; neither one alone is suitable. But combined, the amplitude and phase response is remarkably close to the design target.
Aurum Cantus ribbon - we tried many times to make this work, mostly in the Straight 8 but with the intention of using it with the Climax as another option. The difficulty was a huge resonance around 1700Hz (if I recall correctly) which is quite audible because it is right in the middle of the midrange where the ear is most sensitive. The last crossover design I made for it had a big notch to correct teh resonance, but it did not work as intended and did not alleviate the sonic problem. In addition, the ribbon was very easily damaged by testing (we blew out a number of them) and a half hour of Nine Inch Nails through a Paramount was enough to make the ribbon sag visibly. So I gave up on it, there is no crossover I can recommend. A very airy tweeter, I would not hesitate to use them as a supertweeter crossed at 8kHz or higher, second order or steeper.
Reply #7 on: October 16, 2009, 07:59:46 AM
I think the resonance of the Aurum Cantus G2si (is that right?) was higher than 1700. I want to say it was more like 2200. Or maybe that was just what we accidentally designed for and why the notch filter didn't seem to work too well... Anyway when it comes to ribbon tweeters, even at 5 times the price I would say the RAAL ribbon is worth the difference.
Reply #8 on: October 16, 2009, 08:32:11 AM
Thanks to Michael for digging up this nugget on Straight 8 kit cabinet assembly
http://www.bottlehead.com/straight%208/cabinetassembly/straight8cabinetkit.htm
Offline glynnw
Reply #9 on: October 18, 2009, 11:01:03 AM
I still have the original plans and will try to shrink them from 11x17 to 8 1/2 x 11 so I can scan and email them.  I won't know if they will be legible at this smaller size until I try it.  FYI, the woofers, MCM # 55-1870, are on sale at MCM for 8.95 each for the next week or so.  I have been in the process of comparing 3 speakers;  Straight 8 w/Selenium tweeter, Basszilla and Klipschorns.  Have already decided the Klipschorns come in last place, but still trying to figure out the other 2.  The Basszillas are by far the bass champs of the 3, not because they are overpowering, but because the bass notes are very distinct and accurate. You can really dissect drum recordings because you hear the skin as well as the boom.  But the vocals are another story.  I listen to the basszillas for a couple of days and then swithch to the Straight 8s and just relax more while listening.  Perhaps it is simply that I am more familiar with the sound, but I really think the Straight 8s just do something that is musically right that has nothing to do with detail retrieval or tone quality.  I should also point out that by now the crossover parts in the Straight 8 are almost all higher quality than those I used in the Basszilla.
Offline dbishopbliss
Reply #10 on: October 19, 2009, 03:11:29 AM
Hi all,
Alan
I will be cutting the panels for my ART Array's on Tuesday night.  Then, starting on cutting all the holes!  I'm very curious to listen to an array speaker.  Hoping to have them complete for the next local meet.
David
David B Bliss
Bottlehead: Foreplay I, Foreplay III, Paramour I w/Iron Upgrade, S.E.X. w/Iron Upgrade
Speakers: FE127E Metronomes, Jim Griffin Jordan/Aurum Cantus Monitors, ART Arrays
Other: Lightspeed Attenuator, "My Ref" Rev C Amps, Lampucera DAC
Reply #11 on: October 22, 2009, 06:13:01 PM
This needs to go here,
http://db.audioasylum.com/cgi/m.mpl?forum=bottlehead&n=135255&highlight=crossover&r=
Doc, what is the best way to submit something like this?
...John
Offline Rick Rigler
Reply #12 on: October 23, 2009, 03:44:02 PM
Wow! Wanna trade the Klipschorns for my Straight 8s with the V3 crossovers? With all due respect to the S8. It is a great speaker!
Rick
Horns Love Tubes!
Rick Rigler
Houston, TX
Offline Dr. Toobz
Reply #13 on: October 23, 2009, 06:10:15 PM
I wish I had gotten into Bottlehead stuff before the Straight 8 kits went extinct. The idea of tube-friendly speakers that don't require woodworking (for those of us with no place or tools to do so) and assemble like Ikea furniture is very appealing. I'm really running into problems finding speakers that look nice, sound good, and will present an easy load to my 2W S.E.X. amp. Klipsches seem to bleed my ears, single-drivers seem like over-glorified midranges being asked to play bass and treble, and anything else is too expensive for my budget. I listen almost 100% through headphones as a result.
How much was a pair of Straight 8's as of 2004 when they were discontinued?
Reply #14 on: October 24, 2009, 02:47:22 AM
You have hit many of the shortcomings on the head.  But those are generalizations.  Not all full range drivers are glorified midranges, not all horn speakers shout at you.  To get really deep bass you need a sub woofer.  That is pretty much true regardless of the power you have available.
With no woodworking available (me too) and a limited budget there are only a few speakers out there.  Since this is the Straight 8 thread you should start a thread just for suggestions under this heading?
Doc's old site had a list of tube friendly speakers but I can't seem to find that now.
