Power Supply for Squeezebox Touch
Lar · 46462
Offline HF9
  • Zynsonix.com
    • Zynsonix.com
Reply #45 on: May 18, 2012, 09:46:39 AM
Nice work on that 5V PS Lar, looks very nice :)
My DIY Audio Electronics Blog: DIYAudioBlog.com
Offline grufti
Reply #46 on: May 18, 2012, 05:45:49 PM
...  Just wondering why such a monster of a bridge -- maybe diodes are less noisy when used at far lower than their rated current?
-- Jim
Like the idling motor in a car: very little noise. Wait until you hold the choke in your hand. That qualifies as monster also.
Offline Lar
Reply #47 on: May 18, 2012, 07:00:28 PM
John and Grainger,
Thank you both very much!  You guys rock!  Seems simple enough but the  devil is in the details.  Just wondering why such a monster of a bridge -- maybe diodes are less noisy when used at far lower than their rated current?
I may even have a nice split-bobbin transformer I can sub.  I may even have 90% of these parts on-hand.
Anybody know the O.D. and I.D. for the DC barrell connector for the Touch?
Thanks much -- love this forum!
-- Jim
O.D. - 5.5 mm  I.D. 2.5 Long - 11.0mm   :)  plug size but that should help.
http://ca.mouser.com/ProductDetail/Switchcraft/760/?qs=sGAEpiMZZMu2f9RNbWupYubSmEXlq6O0Wd4VeTPXD68%3d
« Last Edit: May 18, 2012, 07:03:56 PM by Lar »
Larry V
Offline Jim R.
  • Blind Bottlehead
Reply #48 on: May 19, 2012, 04:56:09 AM
Lar,
Thanks very much -- doubly so for the mouser part number.
Got the new Touch yesterday and I'm pretty impressed with the quality of the piece -- as compared to the original SB, sb2 and sb3 -- all of which I've had in the past.
Did you take the electrolytic coupling caps out of your analog outs or are you just using it as a transport?
-- Jim
Offline Lar
Reply #49 on: May 19, 2012, 05:10:26 AM
Lar,
-- Jim
I`m only using the digital out, its all stock, as well as the new firmware for 24/192 output. I have an Emotiva Dac connected to it, impressive sound out of a little box. http://forums.slimdevices.com/showthread.php?94512-Announce-Enhanced-Digital-Output-app-USB-Dac-and-192k-Digital-Ouput
Larry V
Offline Lar
Reply #50 on: May 19, 2012, 05:13:03 AM
Thanks, which box are you referring to? I built two?
Larry V
Offline Noskipallwd
Reply #51 on: May 19, 2012, 05:28:13 AM
Hey Lar, so you are running USB out to the Emotiva DAC. I've heard good things about that relatively inexpensive DAC. So is it asynchronous? I am just using optical out on mine, of course tht is limited to 24/96. I guess I will have to install the firmware upgrade and give it a try.
Shawn
Shawn Prigmore
Offline Lar
Reply #52 on: May 19, 2012, 06:24:04 AM
Hey Shawn, I`m using the coaxial out, the Dac is limited to 16/48 in USB, unless you use USB>SP/DIF converter so i just went coaxial. At 199.00 its a steal, but I expect they are coming out with a new one in the near future to address the USB shortfall.
« Last Edit: May 19, 2012, 06:34:57 AM by Lar »
Larry V
