RE. QUICKIE: ALKALINES VS NICADS
coca · 3852
Offline coca
on: March 02, 2012, 07:14:35 AM
I ordered a quickie kit a few days ago and was wondering if there is a sonic difference in the quickie when using nicads or akalines? The reason I asked, is because I once had a headamp for a moving coil cartage that ran off batteries, and it sounded better when I used akaline batteries comparied to nicads.
Bernie.
Offline earwaxxer
Reply #1 on: March 06, 2012, 02:20:23 PM
Interesting on the sound difference with alkaline batteries. I only have experience with NMH and Lipo rechargeables. Havent really compared them to alkaline though. I have read that Lipo is supposed to have the 'best' sound. Not sure what that means. I think any battery will for sure have less noise than a mains connection. I think it comes down to price and desired voltage. I got some real cheap 14V Lipo packs and put them together to make a 45-50V pack for the Quickie. I think it sounds better than compared to 30V NMH packs that I have for my t-amp. I'm a cheap bastard so I cant stomach the thought of having to go through disposables.
If the voltage is high I would go with Lipo. Low voltages you are stuck with NMH. Forget Nicads.
Eric
Reply #2 on: March 07, 2012, 12:51:33 AM
Every voltage source has an internal resistance that slows the release of energy.  Like low ESR capacitors that can dump energy into a circuit when needed a low series resistance battery might sound better.  It can be measured/calculated.
Offline coca
Reply #3 on: March 07, 2012, 05:06:59 AM
Grainger I think the resistance difference between the nicads, is what caused the difference in sound quality in the head amp.
I have read a lot about batteries on the forum, however I will use alkalines until I decide on my final choice. I am also researching the option of using motor cycle lead acid/gel batteries.
Bernie.
Reply #4 on: March 07, 2012, 09:16:58 AM
Bernie,
MCM Electronics has a wide supply of SLA (Sealed Lead Acid) batteries.  I would buy from MCM but I have a Batteries + just a few miles from me.  They stock them as well.
Offline coca
Reply #5 on: March 07, 2012, 04:33:24 PM
Thanks Grainger, I'll check it out
Bernie.
