Crack as preamp
jimiclow · 16939
Reply #30 on: June 10, 2017, 12:29:09 PM
That connection eliminates the small voltage spike while the Crack warms up if no headphones are plugged in.
Offline AllanMarcus
  • Mainlining my way to bliss
    • My DIY Site
Reply #31 on: June 10, 2017, 04:30:51 PM
interesting. I assume that voltage spike is not good, therefore I guess I shouldn't remove that little wire. right? What's the downside?
This space for rent
Reply #32 on: June 12, 2017, 12:35:41 PM
To be honest, the voltage spike isn't a problem.  When we put out the first iteration of the Crack, we encountered endless threads about the voltage spike, so when we revised the kit I altered the design to make it a non-issue.
As a preamp, the coupling caps in the Crack are kinda big, but if you turn your amp on last, you're not going to have any problems.
Offline AllanMarcus
    • My DIY Site
Reply #33 on: June 12, 2017, 04:42:41 PM
Awesome. Thanks.
This space for rent
