Crack as preamp
jimiclow · 16884
Offline jimiclow
on: March 08, 2012, 07:30:34 AM
Hello!
First post. I'm waiting for my crack kit to arrive. I would like to know if I could use the crack as a preamp.
Has anybody tried this?
Thank you in advance.
SEX 2.1- Alps, Mundorf
Stock Crack
Schiit Asgard, Schiit Lyr
Technics SL1200mkII
Woo WA-6
Reply #1 on: March 08, 2012, 08:01:25 AM
Yes it will work fine as a line level preamp. Of course you won't have the ability to switch sources except by plugging and unplugging cables and you would need an adapter to plug the amp into the headphone jack.
Offline jimiclow
Reply #2 on: March 08, 2012, 04:27:07 PM
Thank you very much for the reply Doc.
So you mean that there would be no modification or addition of parts involved?
Stock Crack
Technics SL1200mkII
Woo WA-6
Offline grufti
Reply #3 on: March 08, 2012, 04:32:28 PM
You will likely throw away a lot of gain in a chain of amps that uses the Crack as a preamp. Take a look at various discussions of "gain structure" by Paul Joppa among many others. Throwing away gain is generally not a good idea.
Reply #4 on: March 08, 2012, 07:44:06 PM
Gain is about 15dB. Rule of thumb is about 10dB for a line stage. So it's not that far off, actually pretty close to the original Foreplay. I think the output jack and lack of selectable inputs are the only real deterrents.
Offline grufti
Reply #5 on: March 08, 2012, 08:59:49 PM
That really leaves just the lack of selectable inputs as a deterrent. Three dollars worth of HOSA cable takes care of the connector issue, if you want to be cheap.
http://www.google.com/products/catalog?hl=en&sugexp=llsin&gs_nf=1&tok=x_5nE6esEeu1SFr6wcNoIA&cp=8&gs_id=ej&xhr=t&q=trs+6.3+mm&safe=off&biw=1333&bih=1052&bav=on.2,or.r_gc.r_pw.r_cp.r_qf.,cf.osb&um=1&ie=UTF-8&tbm=shop&cid=11057247404590733065&sa=X&ei=0rZZT9OMGMbaiQKJz_ioCw&sqi=2&ved=0CEkQ8wIwBQ
I have swapped out the original tubes in my Crack build and forgot that the original configuration has a lot less gain.
Offline dwilli852
Reply #6 on: March 09, 2012, 02:24:50 PM
Ok, couldn't stand it any longer. Connected my Crack to my monoblocks tonight. Very nice sounding. Damn, now I'm going have to build a tube preamp. That means more tube rolling, upgrades and on and on. Will it ever stop?
David Williams
Reply #7 on: March 09, 2012, 02:27:13 PM
Will it ever stop?  No, it is Crack!
Offline jlschweiger
Reply #8 on: March 09, 2012, 03:07:55 PM
Or if you want to use your own favorite interconnect cables:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=090-314&utm_source=googleps
John Schweiger
Chromcast Audio -> Paramounts -> Triad bookshelf
ADCOM-575 -> Smack -> HD800
Offline lextek
Reply #9 on: March 09, 2012, 04:15:00 PM
Oh intersting.....
Bob Lasky
Offline jimiclow
Reply #10 on: March 09, 2012, 06:23:42 PM
Thanks again for all the responses.
Actually, I plan of using the Crack with the Decware Taboo.
Can't wait for the Crack to arrive..
Stock Crack
Technics SL1200mkII
Woo WA-6
Offline grufti
Reply #11 on: March 09, 2012, 08:21:29 PM
In that case you are going to want a fair amount of gain from your preamp. You might very well be hitting a home run with that pairing. Buy the Speedball ... consider a very good 5998 ... wow!
Offline BNAL
Reply #12 on: March 10, 2012, 04:05:35 AM
Don't forget the driver tube. I would read through the Crack tube rolling thread. There is a lot of good information in there about different tubes for the Crack.
http://www.bottlehead.com/smf/index.php/topic,663.0.html
Brad Nalitt
Iron Upgraded S.E.X. Amp 2.0
Foreplay III
Quickie w/PJCCS
Eros Phono
Offline lextek
Reply #13 on: March 10, 2012, 09:24:39 AM
So I had to try it.  Made up a cable from some Kimber speaker cable.  Hooked the Crack up to the little SS amp upstairs.  I really, love Crack.  Especially Speedballing.....
Bob Lasky
Offline jlschweiger
Reply #14 on: March 10, 2012, 12:29:38 PM
Would anyone here be able to offer an opinion about using a speedball crack as a preamp for the Paramounts?  I'm interested in if the output/input impedence is compatible between the two.
John Schweiger
