First Build Problems
Zacwah · 9572
Offline Zacwah
on: March 10, 2012, 02:44:11 PM
So im doin my first build and its all done.
All the ohms check out apart from terminal 7.  it either has no reading or its up and down and gets know where near the 2.9k ohm.
I did the volt test and its reading 230-240 volts on terminals 1,2,4,5.
The tubes glow But there is no sound and when i plug stuff in i get a little zap. Like if i touch the rca connetors and the headphone jack.
gone over the manual numerous times
Will post photos now
Headphones: AKG 702
Headphone Amps/Dacs: Schiit Valhalla, Bottlehead Crack (ordered)
Sources: Schiit Bifrost, Yamaha P-750 (Refurb Project), Sony PS-J20
Offline Zacwah
Reply #1 on: March 10, 2012, 02:50:53 PM
Pics
Headphones: AKG 702
Offline Zacwah
Reply #2 on: March 10, 2012, 06:02:05 PM
The LED's did work but they don't now.
Headphones: AKG 702
Online Doc B.
Reply #3 on: March 10, 2012, 06:11:12 PM
If things keep changing regarding how the amp operates, a good place to start is to reheat all of the solder joints. There might be a cold joint that looks OK, that might actually need a little persuasion.
Offline Zacwah
Reply #4 on: March 10, 2012, 07:05:28 PM
Voltages.
1- 90v  220v
2- 170  231
3-   0    228
4- 170   231
5-  90   230
6-  0    2.2
7- 100   231
8-  0    230
9- 0     230
10- 0    2.2
11-0     230
12- 0
13 170  232
14-0     230
15-185    230
20-0     9
21
a1-90  230
a2-0     0
a3-1.5  230
a4-0    230
a5-0    230
a6-90  230
a7-0    0
a8-1.5  230
a9-0    230
All the B's are 230 bar b8 b7.
i'm not sure whats goin on but thinking something is touching the wrong terminal. Also with terminal 8 and 11 with current does that mean the plate is live too??
« Last Edit: March 10, 2012, 07:08:42 PM by Zacwah »
Headphones: AKG 702
Online Doc B.
Reply #5 on: March 10, 2012, 07:15:00 PM
OK, sounds like something is not grounded. Is this a recent purchase, or have you had the kit for a while? The reason I ask is there were some corrections to the manual in the early days of the kit being shipped. Here is a link to those:
http://www.bottlehead.com/smf/index.php/topic,657.0.html
If it is a more recent purchase, the manual should be correct and it sounds like it might be a miswire, where something that should be attached to ground isn't. Best bet is to run thru the instructions one more time and see if something got missed. It's easy to miss a step, I've done it myself - more than once!
Offline Zacwah
Reply #6 on: March 10, 2012, 08:40:34 PM
Its a recent purchase. Will run through the manual when i get the chance. Would it matter if the Socket A screws and Ground Screw is painted?
Headphones: AKG 702
Offline Noskipallwd
Reply #7 on: March 10, 2012, 11:08:01 PM
ZacWah,
I noticed you have the back side of your top-plate painted. You might want to check and see if you are actually grounded to it. Just test for continuity between the plate and your bus wire. If not, you want to scrape paint from underneath all components grounded to the plate. Don't know if this is the problem but can't hurt to check.
Just noticed in your signature you own a Schiit Valhalla, I own one as well. I think you will be very happy with how much better the Crack sounds, good luck.
Shawn
« Last Edit: March 10, 2012, 11:12:40 PM by Noskipallwd »
Shawn Prigmore
Online Doc B.
Reply #8 on: March 11, 2012, 06:56:16 AM
We don't run signal ground through the chassis plate, just the wiring. So the circuit should be grounded in terms of signal and power supply ground even if the chassis is painted, and the voltages should read OK. The safety ground screw should be in mechanical contact with the chassis, and the toothed washer should cut through the paint for safety's sake, but even if it isn't making chassis contact the circuit should still work.
Maybe try looking at the connections of all of the black wires. What I can see from the photo looks OK, but I can't really see every terminal.
Offline Zacwah
Reply #9 on: March 11, 2012, 10:05:00 PM
There was a few joints i resoldered. No change with voltages.. But did notice if i earth to terminal 12 and test the ohms on terminal 7 i don't get an ohm reading.. but if i earth to the safety ground and test terminal 7 i get a reading of 2.9kohm.
Also after about an hour of being switched off I get zapped off the potentiometer. If I earth on the inside terminal farthest from the chassis and then positive on the top of the potentiometer it reads about 100v.
« Last Edit: March 12, 2012, 12:55:53 AM by Zacwah »
Headphones: AKG 702
Offline Laudanum
Reply #10 on: March 12, 2012, 02:35:09 AM
Looking at your pics, I see some wire insulation burnt (by the iron it looks like)  and some wire leads not trimmed.   You may want to visually check those areas.  Make sure there arent any untrimmed wire or component leads touching adjacent terminals or leads.  Also make sure the conductors of neighboring wires arent making contact due to damaged insulation.
Desmond G.
Offline Zacwah
Reply #11 on: March 23, 2012, 07:30:08 PM
Still no luck after doing the manual again. Have attached some pics of what the terminals look like now.. Probably been staring at it for to long. If the red led don't come on anymore would it be a good idea to buy some more?
Headphones: AKG 702
Online Doc B.
Reply #12 on: March 24, 2012, 06:23:20 AM
The case of the pot having 100VDC on it suggests two things - one, that it is not sitting at ground potential (which it should be since it is in contact with the chassis plate) and two, that the power supply voltage is not being bled off by the 270K ohm bleeder resistor.
Sounds like maybe there is still a missing ground connection somewhere around the power supply. Possibly a miswire or a loose wire. Some of the solder joints still look kind of blob-ish rather than being a smooth fillet. Are you using a solder station, or a plug in style iron? Might need a bit higher temp setting if you are using a solder station, or maybe a bigger iron if you are using a plug in iron.
« Last Edit: March 24, 2012, 06:30:45 AM by Doc B. »
Offline Zacwah
Reply #13 on: August 14, 2012, 08:00:27 PM
So after a few months of hiatus i decided to give this another crack.
I re-soldered most of the connections and now the chassis isn't live!
The valves heat up.
There is no sound and the LED's don't work. Are those 2 symptoms connected??
I have ordered some more LED's and will give them a go.
Headphones: AKG 702
Reply #14 on: August 15, 2012, 12:44:54 AM
When I saw your post this morning it looked like a new post.  So I read the first post and immediately was concerned that you were shocked by the headphone jack.  Then I saw that the underside of the chassis was painted.  You want to unscrew all the screws that are not insulated and sand/grind off the paint where everything is attached to the top plate.  The headphone jack has a signal ground on it that ties to chassis ground at terminal 3.
Also, scrape clean the underside at one corner and attach your meter there.  take all your resistance measurements there.  It will verify that you have a proper ground.  I have listed all Crack grounds in a post and will find that and copy them to here.
Yes, if the LEDs don't light up the driver tube is not on.  That keeps any sound from getting to the output tubes.
The LEDs are not easy to read.  Try checking them with your meter before installing them.  Your meter might have a diode checking position.  Once you see how they work install them upside down so you can see that the silver edge is toward the grounding point (IIRC in Crack that is the center pin of the tube socket).
