Speaker break-in
Natural Sound · 10219
Offline Natural Sound
on: March 18, 2012, 11:42:36 AM
When breaking in a pair of speakers does it matter if they are playing at background levels or, "turned up a bit"? I'm guessing that the break-in time would be longer if done at background listening levels. I ask this question in general terms but I'm trying to break in a pair of Fostex FE 166E drivers. Thanks.
Offline porcupunctis
  • 0D3
Reply #1 on: March 18, 2012, 01:08:21 PM
I broke in a pair of 166e speakers about two years ago.  I ran them for about 8-10 hours per day until I had about 60 hours on them.  I set them at my "normal listening" volume.  At that point they were much better but since then I think they have improved even more.
I'm sure that the volume has some affect on the break-in but I done this often enough to have reliable data to share with you.  I'm sure others will have more to share but it seems reasonable that you would want to break them in at a volume that will at least "get the cobwebs out".
What kind of a cabinet do you have them in?  Mine were in horn cabinets (bk-16).
Randall Massey
Teacher of Mathematics
Reply #2 on: March 18, 2012, 02:14:01 PM
Part of what is "wearing in" is the suspension/spider of the speaker.  So it needs to move.  Background levels are not best for moving the speaker.
I suggest that if you don't want to listen to swap the phase on one speaker, turn them to face each other and throw a couple of blankets, quilts, or bed spreads over them.  This will minimize the sound produced and will flex the speakers.
4krow
Reply #3 on: April 10, 2012, 10:57:26 AM
Couldn't you just sell 'em with a 30 day money back guarantee? Then they will be broken in for you. Seems like the speakers with stiffer surrounds are the ones that take f-o-r-e-v-e-r to break in.
Reply #4 on: April 10, 2012, 01:15:26 PM
Some say, and it makes sense to me, that the fibers of the cone need to break down a little bit. This would ostly happen near the voice coil, where cone stresses are highest. It would provide a little treble reduction, and some damping of resonances - the latter would be especially important for a raw FE166 or other whizzer-cone driver, since the whizzer gets no resonance damping at the outer rim.
I'm sure you could get an argument going on other forums about this, I don't think it's universally accepted. But I believe I first heard of this from Terry Cain, who also said that cryo treatment was worth around 500 hours (IIRC) of break in, but had the disadvantage that half the time the magnets would fall off.  :^)  Maybe Clark would remember better?
If this theory is accurate, then it's the same as with spiders and surrounds, you need to give the cone enough movement to exercise the mechanical parts. For suspension parts, it's going to be displacement (low frequency energy); for the cone itself it will be acceleration (high frequency energy). So it should be excited by a broadband source with a similar spectrum to the end use, i.e. music is an excellent choice.
ALEXZ
Reply #5 on: April 10, 2012, 02:14:40 PM
You can do the following: place speakers face to face, inverse polarity on one of the speakers and play them with normal listening volume. It will be quet and effective.
4krow
Reply #6 on: May 06, 2018, 07:46:04 AM
  This is a post intended to add to the information already addressed here. I have had two different occasions for driver break in. The first was a set of 12" full range drivers from Audio Nirvana. In short, they were unlistenable out of the box. I really wanted to send them back. I decided instead to run them in a bit and see what difference there might be. After only a few hours, the sound became much more acceptable, and continued down that path. They weren't my favorite speakers, and yet, I had few apologies to make for them after the break in process.
  Second in this venue are my present drivers. They are a pair of Decware FRX2 drivers that are heavily modified Dayton drivers. At first listen, they were absolutely beautiful sounding. Then in maybe 10 hours or so, they became bitchy. Hard, harsh mids that mad you wince. That was my prime concern. Only this last week did decide to run them in out in the garage. 88 hours of different music has produced the sound that I had hoped to hear. So glad that I took the time for this process. The drivers and I are getting along splendidly. I no longer wince at some notes coming up. I wouldn't say that this applies to all drivers. I can say that this applies in the 2 cases of these two different drivers, and the time spent made the difference.
