Russian Crack
vetmed · 3385
Offline vetmed
on: March 21, 2012, 10:10:54 AM
Some of you may recall that with PJ's help and calculations I am using 6BX7 as the driver tube. With Speedball set to 10ma current and -5volts on the cathode I get 80 volts at the plate, very cool and just as PJ predicted. So, being mildly OCD I started looking around to see if other tubes might work. Looking at the plate curves for a 6N30Pi I see that at the settings I am using for the 6BX7 the Russian tube should work with only slightly increased plate voltage. Well, it doesn't, I only get around 43 volts on the plate instead of the 90 volts the plate curves predict. Both plates, so I don't think its the tube. I only have one to experiment with. To verify my settings I put the 6BX7 back in and the plate voltage is back to 80 volts. Simply put this puzzles me and flies in the face of my limited understanding of how tubes work. If anyone has any idea what is going on here I'd sure like to know.   Thanks
Robert Lees
Robert Lees
Offline vetmed
Reply #1 on: March 24, 2012, 01:40:32 PM
Well it would seem that perhaps the cathode needed reforming. I went ahead and played it with the ipod set to shuffle and with phones connected for about 3 hours, then measured plate voltage and got what I had been expecting before, about 90 volts on each plate.
Robert Lees
Robert Lees
Offline grufti
Reply #2 on: March 24, 2012, 02:43:06 PM
Well done! I wholeheartedly second trusting one's understanding of the way things work or should work and giving it a go. Your "this can't be true ... I'll shove it back in" approach takes some guts and I'm happy for you that it worked out. Sometimes stuff just comes around to working the way it ought to.
