5814A in Foreplay 2
Pfenning · 6103
Offline Pfenning
  • My knockoffs
    • This is the place
on: April 03, 2012, 04:57:52 AM
So I picked up some RCA Commando 5814A tubes thinking they were the same as a 12AU7. I installed them last night, and turned on my Foreplay. There was a loud hum from both speakers, I'm guessing in the 150hz range. Is the 5814A not the same as a 12au7, or did I get 2 bad tubes? Both channels have the same hum. I switched back to my cleartops and everything was fine.
Pfenning
Pfenning
Reply #1 on: April 03, 2012, 05:10:03 AM
Pfenning,
I've never had a problem dropping a 5814 in directly for a 12au7, so I'm guessing you've got bad tubes.
Reply #2 on: April 03, 2012, 05:53:56 AM
Your problem is not the 5814A.  I have used them often, they are a favorite.  Something else happened.  Post voltages.
I have a list of 12AU7 equivalents for FP 1 and 2 in this folder:
http://www.bottlehead.com/smf/index.php/topic,1027.0.html
These are all drop in for FP 1 & 2 so no problem in FP III.  Some that have higher heater current than the 1 & 2 can supply will work in the FP III since it has more heater current available.  Those are not on my list.
« Last Edit: April 03, 2012, 01:44:56 PM by Grainger49 »
Offline najo49
Reply #3 on: October 03, 2012, 06:06:18 AM
I agree the tube is the same as the 12au7,However I have noticed the same thing but it was a low level hum. In the end I decided as the facts were they are the same,that it was tube problem.
Jann Olsen, [email protected].  Lowther medallion 2 with pm2a./ extended foreplay lll,/EROS phono /Grado ref/ SOTA star Vacuum SME V, /  45 amp direct coupled,c4s,mQ nickel  / paramour  2a3 w MQ iron /Original SEX monos /Jena Cables /heathkit wm6a/ proAc Tablette 50 sig , with push pull
