Alps blue velvet question
NYK35 · 3457
Offline NYK35
on: April 17, 2012, 06:00:55 AM
Hello everyone.  I'm thinking about replacing the stock pot with the Alps.  Would this require any changes/drilling to the panel or will it fit right in?  Thanks!
Offline Laudanum
Reply #1 on: April 17, 2012, 07:51:58 AM
It will only require the hole for the tab that keeps the pot from rotating to be just slightly elongated.   The Alps pots pin is closer to the shaft than stock by a small amount, maybe 1/16 or 1/8".  A small file can be used to elongate the existing hole or a hole can be drilled next to the existing hole.   I believe that the actual mounting hole for the shaft is of appropriate size.  Anyway, it's an easy task and with the new hole being inside rather than outside, the knob will still cover it.
Desmond G.
Offline NYK35
Reply #2 on: April 17, 2012, 10:17:31 AM
Thank you!
Offline Laudanum
Reply #3 on: April 17, 2012, 11:11:13 AM
Happy to help.
Desmond G.
