Warmer than usual top plate and power tube...
liamstrain · 4442
Offline liamstrain
on: May 03, 2012, 07:27:12 AM
I don't recall the Crack I had been borrowing getting quite so warm as the one I just completed does. The top plate and power tube base, especially. The top plate I can continue to touch with mild discomfort, but the Stock 6080 tube base gets hot enough to burn - probably ~200 deg (not that I make a habit of touching that).
All the resistance and voltage checks out, though some of the voltage readings did trend high. 1/5/7/9 were all about 20% high. Everything else was dead on or less than 10-15% high.
Sounds great with only a slight background hiss (assuming tube rush). Just double checking to make sure nothing is wonky.
Reply #1 on: May 03, 2012, 07:53:03 AM
Yup, that's the way a 6080 is supposed to be.
Offline liamstrain
Reply #2 on: May 03, 2012, 08:12:58 AM
Well that's comforting. :)
I'll keep listening and worrying less. It's fantastic with the Beyer 880/600's - those have enough resistance to mask the hiss. With some luck this power tube will burn in and quiet down to where it is less noticeable with the HD600s.
Now to start saving for the speedball. :)
Thanks for a great product and kit, Doc. Was a great build.
Reply #3 on: May 03, 2012, 10:19:29 AM
That is FAQ #4.
« Last Edit: April 01, 2014, 03:10:35 AM by Grainger49 »
Offline liamstrain
Reply #4 on: May 03, 2012, 12:16:19 PM
*thumbsup*
Thanks! I did a quick search, but that didn't come up. (And unfortunately, a lot of undesirable results return for "hot crack." ;)
Offline Laudanum
Reply #5 on: May 04, 2012, 02:25:12 AM
As mentioned by the others, it appears normal and there have been numerous posts about it.   Mine just never gets that hot but I didnt run the straight glass tubes for long,  just the ST shaped 6AS7's and Tung-sol 5998.  More glass with those tubes may have something to do with it.   So would other factors I would think such as where the amp is placed and ambient temperature and air movement.  My Crack sits on top of a stand in a room with a lot of air movement so maybe that accounts for mine running pretty warm but not hot.  Im referring to the top plate here, I dont think I would want to touch the tube glass or base  ;)
Desmond G.
Reply #6 on: May 04, 2012, 05:40:46 AM
The 6080 has a metal base.
Reply #7 on: May 04, 2012, 09:33:59 AM
Because it's direct coupled, the driver plate voltage controls the output cathode. If the driver plate voltage is high, then the output load (big resistor or Speedball) dissipates more heat under the plate, and less in the output tube envelope. Low driver plate voltage reverses that. It could be an explanation.
