Headphone AND Line amp
Wanderer · 18139
Offline Wanderer
on: December 06, 2009, 10:21:41 AM
I read the following in another Quickie thread - a snip of a Doc B qoute:
"....I was using a Quickie that had the Speco transformer mod for high impedance headphones, which is about 3dB down at 80Hz, as a line stage..."
Does this mean that were I to use my headphone mod Quickie as a line preamp I would get responce that was lacking in bass?  Is there any fix for the drooping bass responce from the output RCAs in a Quickie with the Specos? Bigger caps perhaps? ...or rig a switch to take the Specos out of circuit when using as a line amp?
Kevin R-M
Reply #1 on: December 06, 2009, 11:02:01 AM
Yes, I believe that is exactly what it means. To restore the deepest bass, either take the Speco out of the circuit, or replace it with a transformer that has more inductance at small signal levels.
